Stiff Door Lock
15 replies to this topic
#1 minidavid
minidavid
  • 84 posts
Posted 13 December 2009 - 04:26 PM
i know many of us have problems getting our minis to work at times, but is it common to not be able to get in to mine?
its a 1996 mini sprite
been sat on my drive for a few months doing nothing. When i got it the key would go in the both doors fine and turn with ease
now i can just about get the key in the drivers door, but not be able to turn it at all, same with passenger except i can turn it just, but very stiff
anyone else had this problem or should i just put some oil on the locks?
#2 luiji89
luiji89
  • 1,039 posts
Posted 13 December 2009 - 05:19 PM
i have this also, really stiff to lock it!, any advise will be much appreciated
#3 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 13 December 2009 - 05:47 PM
get some release oil squirted in there and work it with the key.
#4 minidavid
minidavid
  • 84 posts
Posted 13 December 2009 - 05:57 PM
cheers ill give it a go, thought it might have something to do with this *melon* weather? only occured recently
#5 adam_93rio
adam_93rio
  • 3,271 posts
Posted 13 December 2009 - 05:59 PM
you can get a special lubricating fluid for lock and barrels
although just spray some wd40 in there and see how she goes. i started to get this problem a bit a couple of weeks ago and this seemed to do the trick
#6 luiji89
luiji89
  • 1,039 posts
Posted 13 December 2009 - 06:13 PM
cheers all
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 December 2009 - 06:33 PM
Don't oil locks, it will make them worse in the long run and make them wear out faster. Oil traps dirt which is what clogs the lock up and causes damage. You need a bottle of graphite powder which is used as a lubricant for locks. It's available from more places than you'd think if you search for it. Whenever I post this people reply that it must be hard to get hold of, simply because they haven't heard of it before and so haven't looked for it!
#8 minidavid
minidavid
  • 84 posts
Posted 13 December 2009 - 06:38 PM
yer i thought there mite be something wrong with oiling them but i dunno y, yeah i never heard of graphite powder but just had a look on internet and it seems pretty common, only like £3 aswell so ill give it a go, cheers
#9 jayare
jayare
  • 2,093 posts
Posted 13 December 2009 - 08:31 PM
Graphite powder is great stuff - my locks got to the stage where I could barely move them. Got some off ebay for a couple of quid, put some in and locks worked great. You should be able to get it from your local locksmiths,
JR
#10 paul6266
paul6266
  • 482 posts
  • Local Club: Retro Classics
Posted 13 December 2009 - 09:09 PM
i used to work as a lock-smith and yes graphite powder is best just very messy, its available from TIMPSONS or WILKOS i would imagine but timpsons will def have it
#11 minidavid
minidavid
  • 84 posts
Posted 13 December 2009 - 09:19 PM
Cheers paul, there is a timpsons about 3 mins from me so ill pop down tomorrow
#12 minidavid
minidavid
  • 84 posts
Posted 14 December 2009 - 05:20 PM
so i got some graphite powder, do i just pour it in to where i put the key and wait for it to work its magic?
wiggle the key about perhaps?
how long should it take you reckon?
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 December 2009 - 01:04 AM
Yes that's about it. It should be in a bottle with a nozzle so you can 'puff' some in. It's a dry lube, the effect should be more or less instant as you would expect with oil.
#14 minidavid
minidavid
  • 84 posts
Posted 15 December 2009 - 03:50 PM
yer it came in the bottle with the nozzle and worked like a treat, a lot easier on passenger door as there was a tiny bit of movement so i managed to wiggle it around and it worked, drivers door there was no play so until i managed to move it that first mm not alot happened but its all good now >_<
cheers 4 the advice
#15 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 23 December 2009 - 05:48 PM
oil has always worked perfectly well on the several minis i have owned
