Whys She Not Start :(
Posted 13 December 2009 - 05:21 PM
iv just come back from uni and i went to start my mini up and its turning over but it seems like its not getting any fuel. Iv checked the tank and its almost full. Im not the best with engines but i know my way round then.
its a 1985 998 city e
its nt been run for about 7 weeks
any help would be appreciated
thanks Tom
Posted 13 December 2009 - 05:36 PM
Posted 13 December 2009 - 05:41 PM
Also try lying one of the spark plugs on the cylinder head (on one of the bolts is usually best) with the lead still attach to it and get some one to turn the engine over. You should be able to see if it sparks. If not check that the distributor cap, coil leads and spark plug leads are secure.
It may seem obvious but as it is cold did you use the choke? If you did possibly it has flooded the engine. Just leave it for a bit and then try starting it once the excess fuel has drained away.
This should get you stated in finding the problem.
Posted 13 December 2009 - 05:52 PM
After turning the engine over have you taken any of the spark plugs out. You should be able to smell petrol on them if petrol is getting up to the head. If not check to see in petrol is getting to the carburettor.
theres a spark and the plug skinks of fuel soooo i think it might just bee flooded
Tom
Posted 13 December 2009 - 07:03 PM
Paul.
Posted 13 December 2009 - 07:58 PM
Posted 13 December 2009 - 09:40 PM
