Rear Foglight Installation
19 replies to this topic
#1 Mi-Cool
Mi-Cool
  • 41 posts
Posted 14 December 2009 - 10:59 PM
Please excuse this question as i fear it may be silly, but i cannot find any previous posts relating to it.
I have this rear fog light from Mini Sport:
Trying to install it, i take it the black wire is the ground, but where do i connect the white cable?
Any help is greatly appreciated as i am new to this >_<
Edited by Mi-Cool, 14 December 2009 - 11:12 PM.
#2 Mi-Cool
Mi-Cool
  • 41 posts
Posted 14 December 2009 - 11:00 PM
Apoligies for the huge picture, no idea why its done that :/
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 December 2009 - 11:02 PM
have you got a sightly bigger picture as i'm a bit short sighted
#4 Mi-Cool
Mi-Cool
  • 41 posts
Lol as i said, sorry for the huge picture, no idea why its done that >_<
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 14 December 2009 - 11:05 PM
is this a replacement fog light or a new one and you need to know how to wire it in ?
#6 Mi-Cool
Mi-Cool
  • 41 posts
Posted 14 December 2009 - 11:06 PM
A new one and need to know how to wire it in >_<
#7 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 December 2009 - 11:20 PM
Should it not just be a easy swap?
the white "braided" cable is live. just connect it to the old fogs live?
or im i missing something?
#8 Mi-Cool
Mi-Cool
  • 41 posts
Posted 14 December 2009 - 11:21 PM
Where can i locate the old fogs live? Because i havent currently got a fog light.
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 14 December 2009 - 11:46 PM
you have a switch for fog lights right?
#10 The-Womble
The-Womble
  • 646 posts
Posted 15 December 2009 - 12:21 AM
I think what mi-cool is trying to say is that he has never had a fog light and so this is a brand new addition to his car and he needs to know what to connect where >_< (sorry, I can't offer much help on the subject though, although I have a feeling that the light blue wire with the yellow stripe which you will find on the loom in the boot is what you need to be plugging in....could be wrong though!)
#11 Mi-Cool
Mi-Cool
  • 41 posts
Posted 15 December 2009 - 11:13 AM
I think what mi-cool is trying to say is that he has never had a fog light and so this is a brand new addition to his car and he needs to know what to connect where ;) (sorry, I can't offer much help on the subject though, although I have a feeling that the light blue wire with the yellow stripe which you will find on the loom in the boot is what you need to be plugging in....could be wrong though!)
Sweet Jesus, finally >_< Thank you. :P
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 December 2009 - 12:44 PM
If the vehicle is pre 1st Apr '80 then it probably wont have the wire for the fog light, you will need to run a live switched live wire from the dash ( where the switch will be added ) through the vehicle to the rear...
After 1st Apr '80 the vehicle should have a fog light as standard and therefore the wiring should be there as above.
However, if a fog light is fitted, irrespective of year, it MUST work and have a tell-tale in the cabin.
Edited by GuessWorks.co.uk, 15 December 2009 - 12:45 PM.
#13 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 15 December 2009 - 01:09 PM
I think you would help the query along if you had stated a year of the car, If indeed there was already a fog fitted, If you had a switch in on the dash for fog lights (thats probably a key question regading the instaliation of the new one you have)! I.E as the above post indicated perhaps the wiring is there if not your talking about fitting a switch in the dash to control the switch and to indicate whether it is on. You will also need a relay.
Do you have front fogs? an option could be to use the switch from them. i run both my front and back fogs form the same switch.
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 December 2009 - 01:50 PM
Shouldn't need a relay for a rear fog, as it should only be pulling 21w max
#15 Mi-Cool
Mi-Cool
  • 41 posts
Posted 15 December 2009 - 11:05 PM
1994, i would just like to know where the pre-installed wire is to attach the white live on the Fog Light...
