A Bright Or Stupid Idea?
19 replies to this topic
#1 trafficface09
trafficface09
  • 757 posts
  • Local Club: not yet but soon
Posted 15 December 2009 - 01:26 AM
i think i have found the answer. as you may know its hard to find any 12x7 so i have been looking around and found that atvs (quad bikes and such) comenly use this size. not only thqat but the pcd is the same 4 inch and they look awesome! but are they road legal if i fitted them with road tyres?
12 x 7 atvs
#2 mike.
mike.
  • 6,176 posts
Posted 15 December 2009 - 01:32 AM
I doubt it because they're not designed to take the weight of a car.
#3 trafficface09
trafficface09
  • 757 posts
Posted 15 December 2009 - 01:34 AM
i just thought about that but i dont... know they look pretty strong and these atvs are quite heavy
edit: just had another thought
if atvs do big jumps also they need to be strong for impact. alternatively i could get them strengthened by an engineer, they look great i really want to try them out.... feeling brave.
anyone else like / dislike them or have any idea how strong they could be? or if they could take a mini
Edited by trafficface09, 15 December 2009 - 01:45 AM.
#4 skaterava
skaterava
  • 1,857 posts
Posted 15 December 2009 - 01:56 AM
ATV's may be relatively heavy but i imagine a mini (with a full tank of petrol) would weigh about four times as much.
I wouldn't try it but if you're willing go ahead >_<
#5 trafficface09
trafficface09
  • 757 posts
Posted 15 December 2009 - 01:59 AM
yeah maybe not such a good idea, but it was close to the answer.
#6 Tim1970
Tim1970
  • 394 posts
Posted 15 December 2009 - 02:10 AM
12x6.5" wheels
LINK
Any reason why you're set on 12's at all?
#7 trafficface09
trafficface09
  • 757 posts
Posted 15 December 2009 - 02:18 AM
£177 each times 4 = id need a job
but they are really nice >_<
oh i wish
12s are just easy. 10s wont fit without break mods i dont have the cash. at the moment. 13s need arch tubing. so 12 is just easy for now, i like the idea of 14s with a beam from a clio or something.
oh and i want 7 width because i have wide arches
#8 Rogue Se7ens
Rogue Se7ens
  • 125 posts
Posted 15 December 2009 - 05:30 AM
There are some really nice looking 10, 12, 13 and even 14 inch wheels made for golf carts and atv available and may work great for sitting at a show but I wouldn't drive on them. I looked into this quite extensively a while back and here in the States they need to be DOT approved to use on the road, but even if you get around that I spoke with some distributors and reps and they said no way.
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 December 2009 - 07:21 AM
next challenge is to find a road tyre for a 7 inch rim
and no and 165/60/12 won't fit
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 December 2009 - 09:00 AM
I think you need to check your assumptions first...
Tubbing the arches has very little to do with the diameter of the wheel, it is related to the ride height... tubbing involves removing the outer radius of the inner rear arch to allow the vehicle to run lower, this is irrespective of the wheel diameter...
If you mean 13's require the front arches to be cut, then yes this is true, but then again, so do 12x6's, the amount of arch which needs to be cut is dependant upon more things than just the wheel diameter, but more importantly, the wheel width, the wheel offset the size and profile of tyre....
In fact a 13" rim with a 175/50x13 tyre is less than 3mm bigger in diameter than a 12" rim with a 165/60x12 tyre on, and is in fact smaller than a 12" rim with a 145/70x12 tyre....
#11 minicitylove
minicitylove
  • 177 posts
  • Local Club: Free Agent
Posted 15 December 2009 - 10:31 AM
is a unique idea but like what was said before i think a mini would weigh a lot more.
#12 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 15 December 2009 - 01:12 PM
a working quad can weigh bout 300kg and if thats pulling a trailer it can be double that but them wheels are prob for a sports quad which would only weigh a max of 200kg so not advisable to use them wheels
#13 trafficface09
trafficface09
  • 757 posts
Posted 15 December 2009 - 03:59 PM
i didnt mention that i will be lowering the ride hight then, opps.
yeah eventually i want to convert to fiesta front breaks then get some nice 10s and some spaxs then lower >_<
#14 trafficface09
trafficface09
  • 757 posts
Posted 23 December 2009 - 01:14 AM
ok im back to this again. would there be anyone out there crazy enough to help me test this. or any way i could test this. ATV alloys are so good looking i cant stand it!
apparently as long as they are not speed weighted they might work, but i was drunk when i heard this so i dono if my mate was right?
#15 rosco454
rosco454
  • 908 posts
Posted 24 December 2009 - 06:39 PM
For the sake of a few hundred quid is it worth the risk?
