Why Use An Electric Fuel Pump?
9 replies to this topic
#1 dinki
dinki
    Starting My Mini Up
  • 1 posts
Posted 15 December 2009 - 05:27 PM
ive recently bought an unfinished mini project,it has a 1340 med engine with a hif 44 carb.to get the car running so i could hear that the engine was ok,the seller used a squeezy bottle full of fuel to a facet fuel pump piped up to the carb to get the engine running.
my question is..do i need to use an elec pump for this setup or is there a better option?
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 December 2009 - 05:28 PM
Just use the standard mechanical pump - it's fine!
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 December 2009 - 05:30 PM
With an HIF44, the mechanical pump should be able to keep up with it, I run a mechanical on my 1330 with an HIF44 and even when it's doing less than 10mpg down the 1/4 it was not suffering fuel starvation.
#4 Mart8V
Mart8V
  • 505 posts
Posted 15 December 2009 - 11:08 PM
I'm with GW- no problem with a mechanical one. Run one on my 1330 and it doesn't miss a beat even at high revs.
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 15 December 2009 - 11:33 PM
Having had a mech one go ... wrong and spit petrol into the oil.
I go electric.
#6 Sherlock
Sherlock
  • 654 posts
  • Local Club: Mini Register
Posted 16 December 2009 - 01:35 AM
I second Big Adam on that, fitting an electronic pump was one of the wisest things I ever did to my Mini, easier starting, no more vapour lock in traffic jams in hot weather & no chance of filling the gearbox with petrol.
#7 Ethel
  • 26,133 posts
Posted 16 December 2009 - 01:47 AM
The best excuse for a leccy pump is it lives at the back, near the tank, so is less effected by inertia trying to empty the fuel line when the car is being flung through the bends.
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 December 2009 - 01:04 PM
All of my British cars will soon have electric fuel pumps. I like them because my cars are for the weekend and may sit for quite a while between drives. With the electric pump you switch on the ignition, give the pump a second or two to refill the float bowls and you're ready to start. Mechanical pumps will refill the bowls also but they obviously require you to crank the engine a bit to achieve the same thing.
Another nice thing about electric pumps is that they are easier to work with if you are trying to diagnose a fuel delivery issue. Quickly stopping the fuel flow is handy if you want to make sure the float bowls are full. Switch off the ignition key and the electric pump stops with no more fuel delivered to the carbs. With the mechanical pump it's very hard to achieve the same thing.
#9 Cooperman
  • 23,350 posts
Posted 16 December 2009 - 03:54 PM
Plus then fact that with an electric pump you can hide a secret fuel pump switch. Then, if someone tries to steal the car it will start, run for maybe 100+ yards, then cut out. The would-be thief won't want to sit in the middle of the road searching for the fault and will, hopefully, just give up and 'leg it'.
#10 Sherlock
Sherlock
  • 654 posts
Posted 16 December 2009 - 04:09 PM
Exactly that happened 3 times when I had my Cooper 'S', thanks to the secret switch it was found each time within a few hundred yards, with no damage.
