Electric Sander/polisher Or An Air Sander For Paint Finishing?
10 replies to this topic
#1 soooty
soooty
  • 261 posts
Posted 15 December 2009 - 08:43 PM
Electric sander/polisher or an air sander for paint finishing?
Have finished painting car and rubbed down with some 800 grit by hand. I dont want to do anymore wet sanding by hand. I see you can get 1200, 1500 amd 2000 grit 6inch sanding discs but don't know what sander to get. The electric ones seem very expensive £50-£100 for somethin decent. Looks as though the rpm can be easily set with an electric sander/polisher. None of them seem to have da function though except for ones that work over 4000rpm that would be no good for polishing also.
Anyway, since i have a compressor i thought it would be cheaper to get a da air sander, these are much cheaper £15- £40 for what looks like good quality ones. But i dont know whether they are suitable for finishing paint with 1500 grit and also for polishing with foam pad and g3 as there max speeds are about 10,000rpm which obviously would burn the paint. presumably i can just set the regulator on my compressor to lower pressure and only pull the sander trigger a small way in to get lower speeds.. but doesn't that mean i am guessing what rpm the sander is working at all the time?? will that work?
Very confused !! appreciate any help ta.
#2 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 16 December 2009 - 12:14 AM
Dont be lazy, do it by hand. IMO you will get a better finish if you take your time and do it by hand. very low risk of burning the paint. and exercise at the same time :thumbsup:
#3 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 16 December 2009 - 12:24 AM
and cheaper
#4 soooty
soooty
  • 261 posts
Posted 16 December 2009 - 12:56 AM
and cheaper
lol its not cheaper if it takes me xtra days that i cud hav spent at work earnin OT. I think i'll do it by hand up to 1500 or 2000 grit and then i'll use an electric polisher with a foam pad and sum G3 after that. ta for replies
#5 Ethel
  • 26,073 posts
Posted 16 December 2009 - 01:10 AM
It doesn't take that much longer if you rub down wet.
#6 midridge2
midridge2
  • 1,794 posts
Posted 16 December 2009 - 08:52 AM
have you really flatted the car after painting with 800 grit, thats far far to course.
#7 jack_marshall
jack_marshall
  • 2,540 posts
Posted 16 December 2009 - 05:39 PM
How many coats of topcoat or clear did you put on?
If you have used 800 your likely to rub through if you havn't already.
Good luck with the 1500 but I fear you will be getting the spraygun out again.
#8 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 16 December 2009 - 06:32 PM
I used 800 on mine, it came out fine >_<
#9 Pauly
Pauly
  • 4,213 posts
Posted 16 December 2009 - 09:34 PM
I would say 800 is to corse for colour sanding, your more than likely get scratches in the paint from the corse paper, I dont go any lower than 1000 grit.
Paul.
#10 soooty
soooty
  • 261 posts
Posted 17 December 2009 - 12:20 AM
yh i kno that but it went on a bit ruff.. i was not sprayin with the usualy 2pac. type paint. its lookin good now though
#11 soooty
soooty
  • 261 posts
Posted 17 December 2009 - 12:21 AM
four
