Should I Drill My Stat?
Posted 15 December 2009 - 09:56 PM
should i drill my thermostat?
and if yes, how many holes at what size?
cheers
Posted 15 December 2009 - 10:04 PM
If your heater is fed from below the thermostat (as in the Metro) then you wont need a hole in it.
If you really want one then drill a small hole in it by why would you?
Edited by zebidee, 15 December 2009 - 10:05 PM.
Posted 15 December 2009 - 10:07 PM
Posted 15 December 2009 - 10:09 PM
essentially the hole is to let through any air, a lot of stats with no holes have a "nick" at the opening edge so air can get through,
I thought its main reason was to allow some flow of coolant around the head during the engine warming up to avoid hot spots
Posted 15 December 2009 - 10:18 PM
Posted 15 December 2009 - 10:33 PM
He means the standard hole, the one with a float valve fitted. The engine needs a bypass of some kind. If there is a chance for the pump to be running without coolant flowing the pump will be more likely to cavitate. The bypass won't make any real difference to warm up time if everything else is working and the bypass isn't excessive.
Ah I see!
Well I can only say that the bypass was the only thing I had changed at that point, and it did take noticeably longer to get up to temperature. Nothing else was changed and nothing was wrong before
Posted 15 December 2009 - 10:34 PM
Posted 16 December 2009 - 08:19 PM
or another theory i have is that i have put the thermostat gasket the wrong way round, allowing coolant to flow from under the thermostat. what should go first, the thermostat or the gasket? or am i just building useless theories?
Posted 16 December 2009 - 08:34 PM
Posted 16 December 2009 - 09:47 PM
Posted 16 December 2009 - 11:16 PM
Posted 17 December 2009 - 12:41 AM
Posted 17 December 2009 - 12:47 AM
How do you know it's taking longer to warm up? Are you going off the temperature gauge? Its sensor is right under the stat and could be proving the point about a bypass ensuring good circulation and even temperatures.
Most excellent point!
