Gasless Mig Welders?
9 replies to this topic
#1 mini e tom
mini e tom
  • 39 posts
Posted 18 December 2009 - 02:43 AM
Are gasless mig welders any good ??
Some people say there crap but others say there little difference so im a wee bit confused :)
i dont want to shed out money for somthin thats useless lol
thanks tom
#2 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 18 December 2009 - 06:59 AM
ive never heard anything good about them. bloke at work has been a welder for 20 odd years and he told me to stay clear of them.
#3 midridge2
midridge2
  • 1,794 posts
Posted 18 December 2009 - 07:15 AM
There has been many postings on this forum asking the same question, some people dont like them and some do.
In my experiance of using mig welders since they were invented i find the gasless mig just the same as a gas mig except the weld is bulkier.
#4 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 18 December 2009 - 08:40 AM
Ive been a welder for over 20 years, there is no major difference. Instead of gas there is a fluxed core in the wire so the weld is messier but cleans up just the same as normal with a grinder. Make sure you wire brush all the dirty flux marks as its corrosive.
Ideal if youre welding outside and its windy, usually cheaper.
Argon/CO2 mix is the best though
Paul
#5 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 18 December 2009 - 11:20 AM
I've used both. as has been said there is little difference when the weld is cleaned up. I'd recommend the type that will take gas as it can be used with or without the cored wire. If you are going to be welding where it's draughty then the cored wire is best. Try welding outside with a gas type mig in a Breeze! I've the scars to prove it
#6 cobblers
cobblers
  • 181 posts
Posted 18 December 2009 - 11:28 AM
I was told that gasless is less good at welding to thinner metal, and when welding up a mates VW van with some gasless wire (after we ran out of gas and normal wire) we certainly ended up blowing a LOT more holes where the metal was thin. It's also annoying to have to constantly wire brush the area.
#7 Ethel
  • 26,183 posts
Posted 18 December 2009 - 11:35 AM
It's not an either or choice, a gasless mig can be set up to run gas. I'd buy gasless for hobby use, it will always be available for odd jobs and you can upgrade with a cylinder if the need arises.
#8 Burnard
Burnard
  • 3,350 posts
Posted 18 December 2009 - 11:46 AM
well the MOT garage i took my car to said the welding was better than most of the 'professional' welding that they see.
I welded my own car with very little experience and a gas-less MIG welder.
#9 Sherlock
Sherlock
  • 654 posts
  • Local Club: Mini Register
Posted 18 December 2009 - 05:27 PM
Couldn't agree more, that's what I did & although there are differences between the 2 types of weld, I got on quite well with gasless but it took me a long time to learn, it will never look quite as neat as gas type, but it's priceless if you run out of gas with a couple of minutes welding left to do! Also, if using gasless, anti-spatter spray is essential.
#10 l_jonez
l_jonez
  • 1,453 posts
Posted 18 December 2009 - 05:45 PM
i've used both for years, personally i prefer it with gas as it doesn't burn as hot so is easier to use on body work but theres nothing wrong with gassless it just needs getting used to.
