ive got little/almost no suspension on the rear left of my car...
the subframe and hi low assembly look fine...
i was thinking maybe the shock had blown? would this cause the suspension to sag the way it is?
what happens exactly when the shock is blown?
Chris
Broken Shocker?
CaptainBland08
, Dec 18 2009 06:06 PM
6 replies to this topic
Posted 18 December 2009 - 06:06 PM
Posted 18 December 2009 - 06:31 PM
Hi Chris,
Shock absorbers have nothing to do with ride-height at standstill. If your car is un-level / sagging, thiks is down to rubber cones or incorrect adjustment on the hi los?
If the shocker has had it, you will see oil leaking down the side of it. Also they will not dampen the bounce - ie press down on the car (in the boot if its a rear shock absorber) - a good shock will let the car rise and fall around 1.5 times. A knackered shock will let the car bounce many times - not absorbing the shock
Ryan
Ryan
Edited by L400RAS, 18 December 2009 - 06:34 PM.
Posted 18 December 2009 - 06:43 PM
ok... so the shock is fine then im guessing... cause it looks completely dry...
the assembly of the hilow looks ok but could the rod have sank into the cone if its goosed?
Chris
Chris
Posted 18 December 2009 - 08:56 PM
Either the cone has had it or the knuckle cup has gone through .....
Posted 18 December 2009 - 09:10 PM
I would second that diagnosisEither the cone has had it or the knuckle cup has gone through .....
Posted 18 December 2009 - 09:17 PM
Or the subframe has rotted through.............
Posted 19 December 2009 - 12:38 PM
found it... the previous owner had adjusted the hi low but not seated the steel cup behind the rubber cone properly...
i just need to take the hi low out and adjust it accordingly WITH the cone seated properly in the subframe... although i will still need a new subframe for the MOT...
Cheers guys...
Chris
Cheers guys...
Chris
