A-panel Vents
Posted 22 December 2009 - 02:05 AM
Posted 22 December 2009 - 10:07 AM
If you believe it will be a benefit drill some holes in your A-panels. Like most things someone somewhere did this and claimed amazing effects. People then copy the mod and the myth continues with no scientific or measured back-up.
There has been an interesting set of articles on Mini aerodynamice in Racecar Engineering over the last 3-months. They didn't try this mod, but my guess is that the effects are not as cut and dry as people are making out.
Posted 22 December 2009 - 07:04 PM
Posted 22 December 2009 - 08:12 PM
I had an idea to put a deflector over the alternator to direct more air towards the radiator and then inside the arch have a similar shaped vent as those carbon ones to direct the air down towards the bottom of the car. My thought was if I could get the shape right the vent would have a kind of venturi affect and draw air down as well so creating a push (from the front) and pull (from the vent) through the rad. Sounds good on paper, what do you think?
Sounds far to complicated....
If a mini needed downforce, they would have bolted some diffusers and a whale tale on it at longbridge...
Posted 22 December 2009 - 08:32 PM
Posted 22 December 2009 - 09:47 PM
Posted 22 December 2009 - 10:15 PM
Not going to be helpful on this thread - but hang on a mo! - a fully steel car with cast iron lump with the aerodynamic properties of a breeze block and there are tricks like this mooted as making a noticeable difference??????? hahahaha - perhaps some super race spec car lightened to bu**ery may see some miniscule benefit but come on - reality check - save a few Kg's - put your obligatory in boot toolbox on a diet to see greater benefit...
Posted 22 December 2009 - 11:34 PM
Posted 22 December 2009 - 11:45 PM
I know what you mean about the heat after driving mine around the N/S wing is quite warm to touch, that's partly what I'm attempting to reduce.
Posted 22 December 2009 - 11:48 PM
use some tigerseal on the back possibly?
Posted 22 December 2009 - 11:57 PM
i didont have some vents attached. it was just 4 drilled holes
Ahh ok. I'm going to make a cowling to go over the vents in the n/s inner wing so the hot air will be forced down towards the road, that should help (I think)
Posted 23 December 2009 - 12:05 AM
Posted 23 December 2009 - 12:39 AM
