Anyone Had Any Troubles With Ball Joints Not Fitting Adjustable Bottom Arms?
4 replies to this topic
#1 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 26 December 2009 - 10:14 PM
Hi All
Ok, bought a set of new adjustable bottom arms a few months back. Fitted them to the the refurbed subframe, and put it all back on the car. No problems. Went to fit the hubs the other day, and the lower ball joint will not actually fit through the hole in the bottom arm.
Because the ball joints are brand new too I thought there must be a manufacturing problem with them. Luckily I've kept the old ball joints in a box, so tried sliding one of them through with no joy atall!
Anyone else had any troubles like this? It's about 1mm diameter too small. Would it be safe to just drill this out very gradually?
Dan :shifty:
Edited by mini-man-dan, 26 December 2009 - 10:15 PM.
#2 icklemini
icklemini
  • 2,982 posts
Posted 26 December 2009 - 10:39 PM
um you do have the right arm on the right side dont you? - the hole where the ball joint goes in is tapered... like \/ - if you have them the wrong way around then they will be like /\ and the pin wont fit through...
#3 mini-man-dan
mini-man-dan
  • 2,684 posts
Posted 26 December 2009 - 10:48 PM
Yeah, well it all lines up and the tie bars attach to the bottom arms, and that can only go one way.
Dan :wub:
EDIT:
Hang on a mo, no. It can go the opposite way. Will check this tomorrow. Muppet of the year award goes to... :shifty:
Edited by mini-man-dan, 26 December 2009 - 10:53 PM.
#4 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 26 December 2009 - 10:53 PM
I would double check there on the right was round as they can be fitted backwards, thus the odd shaped hole wont work as they are sided.
They can only be fitted on the wrong side because they are adjustable though...
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 December 2009 - 12:10 AM
All bottom arms can be fitted on the wrong side if you aren't careful. They are all handed because of the taper pin.
