Few Mini Questions
17 replies to this topic
#1 Jake has a mayfair
Jake has a mayfair
  • 18 posts
  • Local Club: Not yet
Posted 28 December 2009 - 11:42 PM
hi all,,
right 1. my soundproofing on the inside is damp is it worth drying out and putting back in o just trowing it?
2. where can i get new window runners ( i found mine today in the bottom of my door :D )
3. how much does it cost for a eletronic ignition kit and is it easy done?
4. any one know where i can get a cheap and chearful welder from in the nort wales area?
5. and is £450 reasonable for a front end fitted and painted?(anyone here can do it cheaper?)
thanks every one :) !!
#2 rhys mate
rhys mate
  • 41 posts
Posted 28 December 2009 - 11:49 PM
the ignition kit is just over a hundred quid from minisport and all you have to do is follow the instructions given and get it timed :)
just stick a de-humidifier into the car over night to dri it out :D
#3 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 29 December 2009 - 12:17 AM
Have you a machine mart in the local area? They do special days where you can get discounts e.g. 10%/VAT Free days (not sure if its only because I'm trade) but they still have some good kit (Best get a catalogue and do some research)
In regards to the front end.. Is it going to be F/G (GRP) or actual metal panels?
Edited by Twincam, 29 December 2009 - 12:18 AM.
#4 Jake has a mayfair
Jake has a mayfair
  • 18 posts
Posted 29 December 2009 - 12:36 AM
metal panels, andhow easy is the meajolt kit to fit and cost?
#5 rasputin22
rasputin22
  • 251 posts
Posted 29 December 2009 - 12:42 AM
Depends how you do it. For a plug and play around £300 mark, here everything is built and you just bolt it on and everything is included. It does make quite a bit of difference putting one on.
#6 maryquant
maryquant
  • 932 posts
  • Local Club: minidesigner.co.uk
Posted 29 December 2009 - 12:57 AM
window runners available from mini spares, i got a clarke gasless mig from B&Q for 99.99 in the sale
#7 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 29 December 2009 - 08:31 AM
where are you in north wales?
#8 lrostoke
lrostoke
  • 6,923 posts
Posted 29 December 2009 - 09:46 AM
Electronic ignition depends how much you want to spend
You can get kits that replace the points using the standard dizzy housing for £20 upwards or you can go the whole hog and spend a few hundred on a megajolt which will give you pretty much limitless settings to play with.
That £450 doesn't sound bad to me for a front end including paint
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 29 December 2009 - 11:47 AM
Don't bother with leccy ignition - it's NOT necessary! Throw away wet soundproofing (and carpets) and get the car dry inside before fitting any back in. Check the rest of that shell very very carefully - before investing all that cash on a 'front end' - only to find the sills/boot floor rear subframe mounts are rusted away to nothing. Also check the panels behind the fresh-air vents - to see if they too have rusted out!
#10 Minigirlracer
Minigirlracer
  • 382 posts
Posted 29 December 2009 - 11:50 AM
1. If you have the type of soundproofing that fits under carpets like a 2nd sort of carpet then i would just throw it out and get new - when i took mine out it was minging so rather than try and salvage it I bought new.
#11 lrostoke
lrostoke
  • 6,923 posts
Posted 29 December 2009 - 11:58 AM
No its not a necessary but its one less thing to have to adjust and service, for the sake of £20 means no more messing with points and condensors.
I'm not saying they can't go wrong but from experience on 3 minis fitting with electronic ignition all have covered over 25,000 miles with them fitted and no adjustsments needed and all working no problems.
#12 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 29 December 2009 - 10:27 PM
£20? Is that for the kit that eliminates the points?
#13 Steve D
Steve D
  • 128 posts
Posted 29 December 2009 - 10:38 PM
For the kit that is described above, follow the link to my website,
I am based in North Wales ( Jake just give us a shout, you will find my contact details on the website )
#14 lrostoke
lrostoke
  • 6,923 posts
Posted 29 December 2009 - 10:49 PM
yes
http://www.mm-4x4.co...-kit-2720-p.asp
It says Landrover but fits most minis with same type dizzy
#15 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 29 December 2009 - 10:58 PM
yes
I've just bought one, how easy are they to fit?
