Needle Finding
Posted 30 December 2009 - 02:32 PM
ABG
ABN
ADQ
please help
Posted 30 December 2009 - 02:53 PM
Posted 30 December 2009 - 04:47 PM
http://www.mintylamb.co.uk/suneedle/
2 of those needle are near enough same profile as a standard AAC needle.
ABQ is the only one with any real difference but only marginally richer.
But minispares sell the ABQ
http://www.minispare...mp;title=NEEDLE ABQ SWINGING TYPE
Edited by lrostoke, 30 December 2009 - 04:50 PM.
Posted 30 December 2009 - 04:52 PM
Posted 30 December 2009 - 04:58 PM
Posted 30 December 2009 - 04:59 PM
Posted 30 December 2009 - 05:03 PM
Posted 30 December 2009 - 05:09 PM
You'll find your in a minority with your opinion of the AAA lots of people use it.
From the spec you mentioned in your last topic AAA or AAU should work no problems. I'd say the fault lies else where, either the jet is worn or something else.
The AAU is weaker than the AAA so personally I'd give the AAU a try rather than those other needles you mention.
Edited by lrostoke, 30 December 2009 - 05:11 PM.
Posted 30 December 2009 - 07:13 PM
Posted 31 December 2009 - 11:15 AM
Whats your complete engine spec?never using AAA again not good for a 998 engine just floods it and makes it run so badly
And by the way, if you have flooding issues with AAA needles, that means you've a different problem, due to a worn needle valve in the float chamber or again, the float itself incorrectly aligned with the carb.
