Gear Linkage Adjustment
18 replies to this topic
#1 jarmour116
jarmour116
    Just On Tickover
  • 8 posts
Posted 30 December 2009 - 08:09 PM
Hi all, just finished the engine rebuild. However, the gearbox slips out of reverse gear and the reverse lights don't work. This may be because the gear lever doesn't pull back far enough for 2nd, 4th and reverse. I was wondering how do you adjust the gear linkage? Its an A+ engine and rod change box.
Many Thanks
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 30 December 2009 - 08:16 PM
I didn't think the gear linkage could be adjusted in any way???
My initial though for your problem was have you got the correct rod change for your engine? - is it an original part to your car? As if you have fitted a late MPi rod change, or a metro i beleive, these are different lengths (MPi=longer, don't know about metro), and they will give gear selection problems in the gears you have listed (2,4,R)
Ryan
Edited by L400RAS, 30 December 2009 - 08:16 PM.
#3 Ethel
  • 26,018 posts
Posted 30 December 2009 - 08:17 PM
You don't. The steady bar above the selector rod should keep do the job.
#4 jarmour116
jarmour116
    Just On Tickover
  • 8 posts
Posted 30 December 2009 - 08:44 PM
The engine got all gears perfectly when it was removed (MG Metro). But I replaced the gearbox with a newer metro box. Any other ideas? The box worked perfectly when out of the car and the gearbox steady/stabiliser is in place.
#5 Pauly
Pauly
  • 4,213 posts
Posted 30 December 2009 - 08:48 PM
Has the gear lever been removed and put back in the wrong way round?
Paul.
#6 jarmour116
jarmour116
    Just On Tickover
  • 8 posts
Posted 30 December 2009 - 09:00 PM
Paul.
Nope, the lever and the linkage were never removed from the car, only the roll pin from the selector!!
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 30 December 2009 - 11:50 PM
Are the rubber mounts for the gearlever 'box' in good order?
#8 L400RAS
L400RAS
  • 2,479 posts
Posted 31 December 2009 - 07:53 AM
I think this IS your problem; as my original post: all Metro & Mpi rod linkages are different lengths to the standard mini rod linkage change. Did you use the metro rod linkage? - if so, you need a mini linkage
Edited by L400RAS, 31 December 2009 - 07:54 AM.
#9 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 31 December 2009 - 09:37 AM
he already said the gearlinkage has not been removed front the car so is nothing to do with the linkage being the wrong one
the linkage cant be adjusted but if the two mounting rubbers are worn the whols linkage will move rather than the rods
is the little bush in the gearbox casing whrer the upper rod bolts
only other thing can think if your sure gears worked outside the car is was the rod hanging down was the car moved is it bent
#10 Pauly
Pauly
  • 4,213 posts
Posted 31 December 2009 - 10:24 AM
All rod linkages are the same length.
As said, I would check the rubber bushes.
Paul.
#11 THE STIG
THE STIG
  • 2,506 posts
Posted 31 December 2009 - 10:48 AM
no their not metro ones are about 2 inches longer but look the same as mini one but dont line up with the hole in the floor on a mini
dont give out info thats not correct does say at the top of the page
#12 Pauly
Pauly
  • 4,213 posts
Posted 31 December 2009 - 04:43 PM
Correct.
Was half asleep when I posted that, forgot that metros where completly different cars with completly different setups :P.
Paul.
#13 L400RAS
L400RAS
  • 2,479 posts
Posted 01 January 2010 - 09:46 AM
~ also the MPi models had longer rods as the engine sits slightly forward compared to a standard engine / layout
#14 Ethel
  • 26,018 posts
Posted 01 January 2010 - 10:02 AM
I didn't know MPI's have longer rods but it makes sense. 2,4 & R are selected by pushing the selector into the box so this could be down to the engine leaning back too much or the stick being too high. It could be a fault with the gearbox, try removing the selector rollpin an selecting reverse with a screw driver.
#15 Greenmini998
Greenmini998
  • 21 posts
  • Local Club: Guernsey mini owners club
Posted 06 November 2011 - 08:39 PM
Thanks guys youve just solved my commumdium I just coundn't fathom why my reverse gear keep jumping out of gear. And also not immediate problem with 2, 4 gear but I could tell something wasn't right. Ive fitted an late mpi engine into my 1973 clubman. Every thing seemed to fit and locate in the right place ie rod linkage that was fitted to previous engine (1990 metro engine). I know I should have saved that linkage from that knackard mpi mini. Whoops. But thanks again looks like I'm back on ebay tonight oh well .
