What Welder, For A Complete Weld Novice?
Posted 03 January 2010 - 12:11 AM
I'm looking to purchase a Welder to do the usual repair jobs on my current Mini and no doubt others in the future.
What is the best all round easy to use Welder to buy at a reasonable price?
Posted 03 January 2010 - 08:38 AM
this has been asked many times, with lots of answers and links to the mig welding forum
Posted 03 January 2010 - 09:24 AM
http://www.mig-weldi...mig-welders.htm
look here for reviews:
http://www.mig-weldi...isplay.php?f=19
I've got a clarke 160TM and it's been a good machine, but I think a 135 is fine for most mini projects:
http://www.machinema...diy-mig-welders
another consideration is gas or non-gas, but you'll see the pros and cons in the forum above. Good luck!
ps: machinemart have the occasional VAT free day, so if you're not in a hurry, buy something cheap so they get your details then they will post a card to let you know the next date....
Edited by robtheplod, 03 January 2010 - 09:29 AM.
Posted 03 January 2010 - 09:56 AM
Its the gas thats most inportant though, the disposable bottles arent worth it so get an account with BOC or Air Products to get a proper bottle
Paul
Posted 03 January 2010 - 10:23 AM
thin material, this ones ideal
as said by paul you would be best to get an account with a gas supplier, then
you can use a CO2/argon mix gas, better than pub gas (CO2), and the cylinders
last a lot longer than the small shop bought ones. Just a thought you gould pop
rond to a steel fabrication company and see if they would rent you out a
cylinder may be cheaper than going to Boc or Air products.
Posted 03 January 2010 - 02:26 PM
Don't go gasless unless you have no garage and have to work outside. Definitely get yourself a bottle of CO2 argon mix from BOC if you are under cover, although i'm still using just plain CO2 at the moment which is fine but will be converting to CO2 Argon mix when this bottle runs out.
Use 0.6mm mig wire, 0.8 is to heavy for bodywork and also get the larger spool not the small ones from the likes of Halfrauds and if you are doing a lot of welding then buy yourself a good quality mask.
Posted 03 January 2010 - 02:47 PM
http://cgi.ebay.co.u...=item23031fd76a
Has done everything i've needed it to do so far, welded sheet metal upto about 3.5mm thick (without a problem) as well as some metal a guy at my local engineering place said would be about the same thickness as body panels..
Fairly straight forward to setup use etc..
Posted 03 January 2010 - 04:38 PM
Cebora are very good, so good that Snap-On repackage them as their own and add a premium.
Paul
if you join volkszone and go for their group buy you can get a large gas cylinder, gas and rental for a year for £60
Posted 03 January 2010 - 04:44 PM
Thanks for the info guys and the web links, shall have a good look through and pick a suitable one for my needs.
Posted 03 January 2010 - 07:32 PM
i got a cebora 130 turbo battered case but works amazing £100 im no pro but it makes my welding look amazing
Andy
Posted 03 January 2010 - 11:17 PM
you want to look out for something with 8 or so heat settings and wire speed that controls your amperage.
