Metro Rear Wiper?
Posted 03 January 2010 - 03:51 PM
Posted 03 January 2010 - 04:06 PM
First thing would be to hold it up to the window and work out the sweep & arm length to keep the blade on the glass - the blade will be too big and the arm will need modding. It'll probably fit through the rear panel above the boot but the motor may get in the way a bit. A modified Mini windscreen wiper mech would be a more usual route.
Posted 06 January 2010 - 07:17 PM
Impulse purchase?
[/quote]
Posted 06 January 2010 - 07:39 PM
Thanks for your reply. It was pretty much a impulse buy. What with the weather being the way it is i thought a rear wiper would be handy. Do you reckon itl be easier to use a mini windscreen wiper arm instead?
Impulse purchase?
Try using a front arm, I think I'm right in saying that the "Monty Carlo" rally mini's had a rear wiper fitted. I'm sure I have seen one somewhere.
Posted 06 January 2010 - 10:31 PM
Posted 06 January 2010 - 10:58 PM
ERA Turbo.
The motor will fit if it's from the right age of Metro (that's what the Turbo used as original equipment, but you will have to make a bracket) but the arm and blade won't. The Metro rear screen must be getting on for twice as tall as the Mini's. Fit a shorter blade and drill and re-rivet the arm to make it shorter.
Posted 07 January 2010 - 06:44 PM
Posted 08 January 2010 - 12:41 AM
Posted 08 January 2010 - 12:55 AM
We should be able to produce something using the Metro motor.
Even by using a wiper arm from a different model of car.
We need to organise a little GPR time.
If you can get down to the lock up we can sort it for for, especially the fitting of the motor and the necessary wiring.
Scott
