Mpi Front Mounted Rad - Onto An Spi Or Carbd Model
10 replies to this topic
#1 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 04 January 2010 - 05:10 PM
just wondering when i broke mine down the other day how different the mpi setup is to the spi or a carb cooling wise (dont know much about mpi's)
is it easy as in buy the bits and theyll fit straight on or is it a faff around to convert it.
any info atall would be cool, maybe even piccys of an mpi bay?
Thanks :D
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 January 2010 - 05:12 PM
different subframe for a start ( but suppose it could be made to fit ), the alternator is raised in the Mpi to allow room for the rad, and the block is different with no Dizzy and the oil filter is moved up and onto the block..
However, many people have fitted front rads to std minis..
#3 rick.spi
rick.spi
  • 1,686 posts
Posted 04 January 2010 - 05:15 PM
ah, i feared this might be the case. :)
i'll leave it and carry on with the important things, as it sound expensive.
Thanks for the info guessworks. :D
#4 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 04 January 2010 - 05:19 PM
hold on, im interested in this too, how hard is it to install the expansion tank ect, i have loads of room for the rad with my square nose lol
#5 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 04 January 2010 - 05:54 PM
piece of *yellow human water* in a clubby..
this is a metro radiator setup with an mpi fan:
i'm now running an alloy cinquecento radiator with slightly different piping runs.
Edited by bud666, 04 January 2010 - 05:54 PM.
#6 rasputin22
rasputin22
  • 251 posts
Posted 04 January 2010 - 06:37 PM
cinquecento radiators are quite compact and may fit nicely in a clubman front.
#7 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 04 January 2010 - 06:52 PM
they're a similar size to that type of metro radiator but with both outlets at the same end.
there was another type of metro one though that wasn't quite as wide but had a thicker core and both outlets at the same end, they also fit pretty well.
Edited by bud666, 04 January 2010 - 06:54 PM.
#8 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 04 January 2010 - 07:04 PM
Just use a decent supercool 2 or 3 core radiator... just not a 4 core! Otherwise by the time the air gets to the 4th core it's hot and doesn't cool anything :D
#9 orcadian
orcadian
  • 203 posts
Posted 04 January 2010 - 08:44 PM
Hi,
My Clubman Estate has MPI running gear with front mounted rad on home made brackets. On a round nose you could use genuine MPI top brackets with a home made lower one. Alternator would still be a problem though. There are some pictures on my site of my installation if you need a shot of the bay.
http://www.stallard-...ubmanestate.htm
#10 MiniJosh92
MiniJosh92
  • 1,709 posts
Posted 04 January 2010 - 09:19 PM
I'm running a metro front rad in my clubby estate. I used everything from the metro - hoses, fan, expansion tank etc. It goes in really well, I just had to shorten the top hose a bit.
I'll get some pictures if its of any use to anyone?
#11 Pete297
Pete297
    Starting My Mini Up
  • 4 posts
  • Local Club: Looking!
Posted 12 February 2010 - 07:44 PM
Hi MiniJosh92,
Any chance you could get some pictures?
I bought my 1275gt like this,
the radiator leaks and the hoses are good for nothing so need replacing, (ongoing project). I'm not sure what the top hose is and the bottom hoses are a mess/bodge I'd like not to repeat. Are the bottom hoses you used an off the shelf part?
Peter
