Mini Clocks
9 replies to this topic
#1 henry marchant
henry marchant
  • 52 posts
  • Local Club: no but want to join one
Posted 07 January 2010 - 11:51 AM
hi i have a 1982 2 austin mini its pretty standard
at the moment it has 2 clocks
but i wanted to know if i could upgrade it to 3 clocks
i know i will have to get a new dashboard but what else would i have to do?
any help would be great thanks
#2 chrisgonz1
chrisgonz1
  • 186 posts
  • Local Club: Purely business!
Posted 07 January 2010 - 12:20 PM
im not very Tech Savvy but.... I think you can just unplug the two clocks and plug in a 3 clocks? :)
#3 henry marchant
henry marchant
  • 52 posts
Posted 07 January 2010 - 12:27 PM
but where would the rev meter get its drive from?
#4 chrisgonz1
chrisgonz1
  • 186 posts
Posted 07 January 2010 - 12:32 PM
:) hhhhmmmmmm
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 January 2010 - 12:39 PM
Generally the wires for the Tach are already in the loom, however to put a tripple clock in you will also need the carrier frame for the clocks unless you are putting in an aftermarket dashboard...
Look behind the clocks for a white wire with a female spade terminal an a white/black wire with a bullet connector...
#6 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 07 January 2010 - 01:31 PM
Myabe not the correct place, but I am going to be replacing my wooden dashboard with 3 main clocks, included for a centre speedo. Mine also has 3 small holes for guages and DIN for radio, glove box on left and two holes for fresh air vents if you were looking to buy a used set?
#7 henry marchant
henry marchant
  • 52 posts
Posted 07 January 2010 - 04:03 PM
cool could i maybe see a picture?
#8 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 07 January 2010 - 06:53 PM
Sure, can I email it to you, if you send me your email address in a private message. Cheers.
#9 henry marchant
henry marchant
  • 52 posts
Posted 07 January 2010 - 09:38 PM
its OK i have seen it on the classifieds but i have decided to try! and make my own!
#10 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 08 January 2010 - 09:33 AM
Ok, good luck. by the way, I have not advertised it anywhere.
