Model:998cc engine mini city
Year:1989
i have a bog standard 998 engine in my mini. and as im 17, i dont want an "engine transplant" to keep my insurance down.
i have a few questions. how many "stage" kits are there? like stage 1, stage 2 etc
also, are they easy to fit to the engine?
thirdly, could i also fit a way of forced induction to the engine? or is it nor worth the effort?
(p.s) i dont know what the stage kits do, so if they are forced induction, i appologise for my ignorance
thanks
chris
Upgradeing A 998cc Engine
Kwik
, Jan 07 2010 12:49 PM
7 replies to this topic
Posted 07 January 2010 - 12:49 PM
Posted 07 January 2010 - 01:01 PM
On a well maintained engine a stage 1 kit which includes, a free flow air filter, new needle for the carb, an inlet manifold, free flowing exhaust manifold and exhaust system, should give between 10 and 20% performance improvement over a std 998.
You will need to notify your insurance company of the modification but it's a common mod and should not affect it too much...
Anything over that you're looking at engine mods which will bump the costs...
Posted 07 January 2010 - 01:40 PM
sounds promising...
is there anything else i could do to it to increase the BHP?
Posted 07 January 2010 - 01:48 PM
next step would be a modified head to allow the engine to get the gasses in and out better
could add up to another 10-15% depending on spec of the head
Posted 07 January 2010 - 02:36 PM
head and cam will give the biggest increase, but go the stage 1 first as said. also a rolling road session will do wonders too.
Posted 07 January 2010 - 04:26 PM
thanks for the advice guys even if some of it is comming from a chelsea fan
(only kidding)
i realised i could never afford a full engine conversion with rollcage and 400 odd horse power, so iv decided to make a small engines light car instead, and have poly carb windows to save weight, strip the car etc etc
chris
chris
Posted 07 January 2010 - 04:29 PM
Be sure to clear anything with your insurer first though before you do it.
Posted 07 January 2010 - 04:40 PM
All the above is correct, start with a stage 1 kit, then for more power comes an uprated head and cam.
Just so you know our fast road 998cc engine (basically with a uprated head and cam) put out around 65bhp average depending on the cam, the same as a 1275. So thats the kind of power you can expect.
Chris @ Smart Performance
