How To Remove A Gasket
6 replies to this topic
#1 LESTA MINI
LESTA MINI
  • 492 posts
  • Local Club: 4th Gear Mini Club
Posted 08 January 2010 - 09:04 AM
hi guys, after different people telling me different ways, whast the best way to remove old gaskets from gernal bits of the engine.
cheers dan
#2 Pooky
Pooky
  • 5,691 posts
Posted 08 January 2010 - 09:11 AM
Use almost whatever you like, as long as you don't scratch either of the mating surfaces. You can buy various products that aid removal of gaskets and sealants, then you could use a plastic or wooden scraper to be safe. However you can see in the kit below that a steel scraper is used which is fine as long as it is kept flat to the surface.
Frosts Gasket removal kit.
Which gaskets are you talking about in particular?
#3 Asphalt
Asphalt
  • 2,173 posts
Posted 08 January 2010 - 09:17 AM
Those cheap plastic paint scrapers work brilliant! :lol:
#4 Big Guns
Big Guns
  • 395 posts
  • Local Club: NORTHANTS M.O.C
Posted 08 January 2010 - 09:18 AM
I generally use a decent chisel! Keep it flat to the surface though. I also use brake cleaner to remove any residue. When reassembling use a GOOD quality gasket sealer along the lines of Hermatite.
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 08 January 2010 - 09:27 AM
Gasket sealant should definitely not be used on Every gasket though - and if the surface prep is good + gaskets aren't the cheapest set you could find, then there shouldn't be a need anyway.
In anycase - We need to know which gasket you're replacing really. Is it the rocker cover gasket (looking at your previous thread)
#6 Pauly
Pauly
  • 4,213 posts
Posted 08 January 2010 - 12:05 PM
I remove any gasket with a stanley blade then get some wet and dry to remove the stubbon parts, leaves me with a nice flat, clean surface for the new gasket.
Worst part of engine building this is :lol:.
I like them scrapers though, been after one of them for quite a while.
Edited by Pauly, 08 January 2010 - 12:05 PM.
#7 jkjaxor
jkjaxor
  • 331 posts
Posted 08 January 2010 - 12:14 PM
i usualy use a stanly blade and paraffin or petrol to remove gaskets if the whole thing is in pieces, then seal the new one on with gasket sealant, if it is any of the ones around the gearbox dont use sealant as they are made to be a certain thickness,
jack
