Cooper S Dizzy
Posted 08 January 2010 - 03:45 PM
Posted 08 January 2010 - 04:09 PM
Posted 08 January 2010 - 04:33 PM
Posted 08 January 2010 - 04:38 PM
Posted 08 January 2010 - 07:18 PM
Posted 08 January 2010 - 08:30 PM
I'll look it up if no one knows off hand.
Posted 08 January 2010 - 08:34 PM
Posted 08 January 2010 - 08:37 PM
It's because it's off an 'S' everything from the 'S' makes yer Mini go faster....not.The lack of advance is the answer - although some basic van models didn't have advance either! There is a part number of course - I just can't remember it now - and it's too cold to go out to the garage and look at the S dizzy I have there! But why the excitement ? It wasn't otherwise 'special' in any way - although stronger sprung points were specified for the S engines.
The Morris Marina was very similar and had no vac advance for some reason , something to do with crank rumble problems I believe.
Posted 08 January 2010 - 08:50 PM
Posted 08 January 2010 - 09:17 PM
Posted 08 January 2010 - 10:44 PM
Depends on which 'S' it was taken from.That's the number I was looking for! Well done. Since we are on the subject - does anyone know what mechanical advance was built into that dizzy ? I robbed the bits from mine years ago - to put in a dizzy WITH vacuum - and it's long gone now.
the static figures might help you as they advanced from that to about 30 degrees
The 1071 was 12 deg static
The 1275 was 2 deg static
These figs would suggest a lot of built in advance so prob a 15 deg dizzy
I know the last 'S' models used a 10 degree dizzy but they had vac advance.
Hope that is of some help.
Posted 08 January 2010 - 10:46 PM
Posted 08 January 2010 - 10:52 PM
Good dizzy for a 998 that, set it up at 5 deg BTDC static as it was in the cooper and it will go well.cheers chaps, i have looked it up and it turns out its a 998cc cooper dizzy (up for sale if anyone is interested)
Posted 09 January 2010 - 02:03 AM
http://www.starchak..../pdfs/lucas.pdf
Search the PDF and you'll find three 40819 dizzys includes some data on their advance curves. Marcel also has a PDF on tuning the Lucas dizzy and it has more information on the 40819 advance curve and components:
http://www.starchak....lucastuning.pdf
Posted 09 January 2010 - 07:12 PM
The last S distributor was the 41033 but it still didn't have a vacuum advance.
