My 1060cc Engine Build
217 replies to this topic
#166 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 April 2011 - 10:52 AM
Ah fair enough :D
Yeah sw10 idle could be interesting...
What was your final spec pete and what was it like to drive?
#167 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 06 April 2011 - 11:29 AM
Naa SW10 is fine (Well apparently its a hell of a thud around 5000 rpm), I think you'll find with your mappable ignition you will iron out most of the lumpiness! the only issue I was thinking is that with an 87 shell, I don't know the rules on emissions, but again the ignition timing should help you there!
#168 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 April 2011 - 10:37 PM
Hell of a thud at 5k? What do you mean haha
#169 liirge
liirge
  • 4,097 posts
Posted 06 April 2011 - 10:41 PM
It really takes off all the way to 7k!
#170 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 April 2011 - 11:41 PM
mmm. SW10 still has less lift than the one im planning to put in my 998 :/
Edited by twrminisport, 06 April 2011 - 11:48 PM.
#171 liirge
liirge
  • 4,097 posts
Posted 07 April 2011 - 12:35 AM
oh that'll be interesting what are you going to be using then? How does it do in terms of duration?
Edited by liirge, 07 April 2011 - 01:39 AM.
#172 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 07 April 2011 - 10:47 AM
Received a very nice paper weight from Minispares yesterday :withstupid:
#173 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 07 April 2011 - 11:00 AM
Morspeed MSPD Trackday cam that i am getting from a friend.
Duration is 270 on Both but the lift is 0.315 on inlet and 0.311 exhaust Power band from 1800 up
Valve lift (inlet/exhaust)
1.25 0.394 0.389
1.3 0.409 0.404
1.5 0.472 0.467
1.7 0.535 0.529
And the SW10 has a duration of 280 on both but the lift is only 0.291 on the inlet and exhaust. Power band is 1800k up
1.25 0.364 0.364
1.3 0.378 0.378
1.5 0.436 0.436
1.7 00.495 0.495
So yeah the SW10 has duration of 10 longer but the Trackday cam has a much better lift. I think in a small bore this will be much better and produce better figures?
Thougts are VERY welcome and much needed :withstupid:
#174 liirge
liirge
  • 4,097 posts
Posted 07 April 2011 - 11:42 AM
1.25 0.394 0.389
1.3 0.409 0.404
1.5 0.472 0.467
1.7 0.535 0.529
1.25 0.364 0.364
1.3 0.378 0.378
1.5 0.436 0.436
1.7 00.495 0.495
Possibly, but I doubt the extra lift will equate to much due to size of the bore it wont need all that lift to fill the low litreage, where as duration helps more to fill the bores with air fuel mix as efficiently as possible using what i like to call the inertia effect.
Where did you get those SW10 figures? I've never seen figures for the SW10-07 only the older SW10....
#175 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 07 April 2011 - 04:26 PM
Interesting...
I read somewhere max duration for a 998 is 270
Any ideas?
Err the camshaft guide I've got :withstupid:.
#176 liirge
liirge
  • 4,097 posts
Posted 07 April 2011 - 04:37 PM
maximum for driveability, but im not going for that, as long as you can rev it high enough its fine to goto 286, in fact i think Vizard even suggests it on all out 998 motors.
#177 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 07 April 2011 - 11:37 PM
Okay i will think on it. Do you think trackday cam or a new sw10?
#178 liirge
liirge
  • 4,097 posts
Posted 08 April 2011 - 11:06 AM
track day...its something different
#179 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 18 April 2011 - 04:35 PM
A couple of updates:
Minispares Diff, hasnt been built yet but looks nice!
New MED x-lite back plate, new bolt and key washer
Fuel and oil breather unions
and Stripped the Gearbox :genius:
Taking all the casings to Brett Sims Motorsport to be sandblasted and cleaned up, so can start rebuilding it soon :dontgetit:
Ben
#180 Timinichelsea
Timinichelsea
  • 215 posts
Posted 18 April 2011 - 04:45 PM
Nice linkage, i like that style they give an excellent firmness to the accelerator pedal.
I cant wait to get my engine so i can start going OCD with the neatness.
I'm sure you are but I hope you're going to be as neat with the engine wiring.
