Makes me want to get a webber on mine, still think you should go for a more lairy cam to make the most of the engine, im using a sw10/286 and in my 998 and driving it everyday, once it gets past 3k you wont regret it espically if you have everything lightend and balenced. IMO theres to much hype about big cams being undrivable around town, but its your engine though
My 1060cc Engine Build
#31
Posted 06 February 2010 - 02:45 PM
#32
Posted 13 February 2010 - 06:37 PM
Right, over the last couple of weeks the crank, rods, flywheel and pistons have been away at Saunders Engineering down the road from me, to have the crank polished, all balanced and the pistons decked by 18thou to be flush with the top of the block.
Was all finished at the start of the week, so this morning I spent afew hours assembling it all...
Crank and Cam in..
Nice alloy front plate... found out that my cam end plate was bend, so new one of those on order
Rods and pistons in.. nice ARP rod bolts
Other than that iv ordered a couple of bits and pieces and now its time to start rebuilding the 'box
Ben
#33
Posted 13 February 2010 - 06:48 PM
Where did you get an alloy front plate from? Also what have where have you bolted the engine onto the stand?
#34
Posted 13 February 2010 - 07:10 PM
#35
Posted 13 February 2010 - 08:02 PM
Looking good!!
The plate is from MED, very nice
This is going to be one hell of a build
Thanks very much.. I hope so!
#36
Posted 13 February 2010 - 08:23 PM
MRA Minis Head Gasket
It was specially designed (for my Mini
#37
Posted 13 February 2010 - 08:24 PM
Might have to have a word with saunders about some work in the future.
Look forward to seeing the final result.
#38
Posted 13 February 2010 - 08:52 PM
Don't know if you know about these but Martin at MRA Minis does special head gaskets for 12G940 onto small bore block.
It was specially designed (for my Mini) to ensure that the edges of the gasket don't sit over the waterways of the block.
Ah fair enough, hadn't really given the head gasket much thought at the moment, but yeh I had seen that.. will have a chat with him
Looking great mate very impressed.
Make sure before you drop anything off at Saunders you have a healthy bank balance... ended up being about twice what I thought it would cost.. very good work! but very expensive!
Im looking forward to it too
#39
Posted 13 February 2010 - 09:22 PM
Should be an absolute screamer!
#40
Posted 15 February 2010 - 08:32 AM
The alloy front plates are also available on ebay from a chap in the states who first came up with the idea - cheaper than MED too even posted from overseas.
#41
Posted 15 February 2010 - 09:18 AM
JD
#42
Posted 15 February 2010 - 06:56 PM
Some nice details in that build - I like the centre main strap but would advise using hardened washers under the bolts. I'd also check your cam sprocket has clearance on those three cap heads, they look to sit quite proud.
Hey
Thanks very much for the comments.
I had the main strap made by my engineer as the previous one I had didn't have locator's for the trusts.. not good! just took it back to him today to have the locator's machined down by 1mm either side as they came very close to the crank!
Ah yes.. Washers, will do! thanks for that.
Honestly looking back through my receipts, I did actually by the front plate through ebay from that guy and not MED ( Iv brought too much to remember!
The cap head bolts for the cam sprocket were just thrown on there to hold it down before the gasket sealant dried, but I do have some of the original flat bolts to go in there.
You are very observant!
Ben
#43
Posted 15 February 2010 - 07:03 PM
) Can say that its very good quality! now needs abit of a clean as it has oily marks on it.
Ah, I have one coming from MED anyway, thought I would get them to stick one in with all the engine bits which should be with me soon
Look forward to seeing more progress
#44
Posted 16 February 2010 - 09:51 AM
Certainly looks like this will be a good, solid built motor.
#45
Posted 16 February 2010 - 10:39 AM
Make sure the washers are hardened - normal plain washers will simply deform under the head of the bolt and not provide a reliable clamping force. And well done for using decent grade bolts rather than the crappy 3 dash grade stuff that most suppliers send out (apart from MiniSpares who I believe not supply the correct grade).
Yeh, Im just looking for hardened washers now, any idea where to get them from?
I called around lots of different companies to see what main bolts they all use and everyone said 'the standard ones are fine' but I just didnt quite believe them, so found someone who builds se7en's engines and he sent me these
http://www.shengineering.co.uk/
Ben
