It's given me some inspiration reading through this, top stuff
Matt
Posted 24 December 2010 - 12:18 PM
Posted 29 December 2010 - 11:24 AM
i reckon you should get a 1275 and make that get 90bhp probably cheaper.
Thanks for that.. I know that its cheaper and easier to make 90bhp from a 1275, done it more than once..
but I would like to do it with a small bore, as it interests me.
Ben
Posted 29 December 2010 - 11:45 AM
Posted 29 December 2010 - 12:17 PM
Engine looks wicked Ben, small bores are da bomb.
I'd be interested to find out what you think of the ECU once it's all up and running, it's something I keep thinking about doing on the estate.
Posted 29 December 2010 - 09:14 PM
Posted 29 December 2010 - 09:35 PM
Where do yo get the nuts for your head from they look awesome:)Here you go...
Alternator is mocked up.. just waiting for the long M10 bolt to arrive to bolt it together.
Ben
Posted 29 December 2010 - 09:55 PM
Posted 29 December 2010 - 10:18 PM
Why have you got the second mount on the block for a 2 mount alternator?
Posted 30 December 2010 - 08:21 AM
As good as the carbon fibre bits look, I cant help but think its going to have a crunch as it first pulls off, as the carbon fibre breaks
Only time will tell i suppose, good luck
Posted 30 December 2010 - 09:50 AM
Hey ben how is your oil filler cap attached to your rocker cover? I'd really want a carbon rocker cover myself but the filler cap would have to come out the side or it will come into contact with my bonnet as i've got a minus and it takes 3" out of the engine bay! Regards BlueWhy have you got the second mount on the block for a 2 mount alternator?
I have the alternator mount on the block because I plan to run a M10 150mm bolt through the alternator and water pump and over to the block mount, Iv seen alot of these type of alternators only mounted in 2 places snap off the end of the water pump.
What do you mean about the carbon breaking? Which bits? Each piece has been made to exceed the strength of the original metal part.
Ben
Posted 30 December 2010 - 10:26 AM
Posted 30 December 2010 - 10:51 AM
Beautiful!
Though... that alternator looks so plain there... remaking that tin end cover in carbon would help it fit in
Chris
Posted 30 December 2010 - 11:56 AM
Posted 30 December 2010 - 12:03 PM
Posted 30 December 2010 - 12:23 PM
I didn't say it would break just cant help thinking it would/will.I have the alternator mount on the block because I plan to run a M10 150mm bolt through the alternator and water pump and over to the block mount, Iv seen alot of these type of alternators only mounted in 2 places snap off the end of the water pump.
Ben
