Would A Spi Head Work On A Standard 1275 Metro Engine?
12 replies to this topic
#1 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 04:45 PM
Model: Rover Mini City E
Year: 1990
Hi Guys, (hope this is the right section of the forum)
I've recently bought another Mini but soon learn't that the engine had infact been swapped some time in its life to a 1275 lump.
I've searched the net and found that the engine was in fact a Standard Metro (Pre October '84 low compression unit) with the numbers 12H907AA stamped into the plate. I also have a 12G940B Mini SPi head and have a few questions as follows...
1. Would the 12G940B give me any peformance/running gains over the standard head?
2. Would it be a straight fit (apart from the bypass hose needing to be blanked off and thermostat drilled)?
3. When did the heads start becoming Unleaded?
4. What does it mean when it says its a low compession unit?
Also, I saw a central oil pick up pipe on eBay and don't really have a clue about them... (Just thinking before I assemble the engine if theres anything which is worthwhile putting in there). Are they worth it?
Thanks in advance,
Hasan
#2 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 07:35 PM
Anyone?
#3 mars red mike
mars red mike
  • 1,500 posts
Posted 11 January 2010 - 07:57 PM
Unless the head you already have fitted is worn, no you wont see any increased performance. (Assuming the SPi head is standard of course)
Yes its a straight swap apart from what you have mentioned.
Unsure of the exact year but all injection engines were unleaded.
4. What does it mean when it says its a low compression unit?
Not totally sure. I think its something to do with the dish of the piston but maybe totally wrong.
Ive not had any experience of them personally. Some people rave about them, others hate them. Better answered by someone who has got one
#4 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 08:00 PM
Thanks for your help, hopefully someone will be able to go into more depth regarding the low compession unit.
Hasan
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 January 2010 - 08:34 PM
If you intend doing any rapid cornering - you NEED the center pick-up pipe! The head should fit ok - but won't be any better than the standard head.
#6 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 08:41 PM
Are the heads basically identical apart from the sleeves being able to withstand the unleaded fuel (and the bypass hose)?
#7 wile e coyote
wile e coyote
  • 1,230 posts
Posted 11 January 2010 - 09:03 PM
12G940B is the std unleaded 1275 head - essentially the same as you'd have with a standard 1275 12G940 (valves in the early leader MG versions are bigger and i think the ports are fractionally improved in those) to run a "B" suffix version in addition to the bypass take off (if you need one???) / holes in thermostat , the majority of these heads have no tapped hole for a temp sender (only ever seen one that did - balnking plug fitted) - a reasonable machine shop will tap this for less than £20 . You can easily drill out the hole for the heater tap the mounting stud threads are already there and tapped...
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 January 2010 - 09:05 PM
You can get a thermostat cover with temp take off tapping - no problem there - but there seems no point/advantage in this head swap . Why are you thinking of it ?
#9 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 09:09 PM
I bought it as it is unleaded and already for me to just plonk onto the Metro engine - not sure if the Metro lump has the 12G940 head on it? (or was there only two types?)
Was the original temp sender in-built within the ECU unit on the SPi units?
Edited by Twincam, 11 January 2010 - 09:10 PM.
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 January 2010 - 09:14 PM
Don't worry about 'unleaded'! Just set exhaust gaps to 15 thou - and check/reset them every 3000 miles. It will be fine.
#11 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 09:22 PM
Now you tell me! :)
In regards to the SPi head, should I keep it as spare (I do have a Cooper SPi too) and maybe modify it (gas flow/port it) or off load it?
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 11 January 2010 - 09:24 PM
Certainly keep it - useful spare - prices certainly not going down!
#13 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 January 2010 - 09:29 PM
Thanks for that, by the way do you know what it means when it says the unit is a Low Compession Engine?
