Mini Wont Start!
#16
Posted 15 January 2010 - 05:50 PM
#17
Posted 15 January 2010 - 05:51 PM
#18
Posted 15 January 2010 - 06:01 PM
To check if there's petrol coming through, I find it easiest to just unscrew the jubilee clip holding the fuel line from the pump, into the carb. undo that and then turn the engine over for a split second.
You should see petrol come through the pipe. Put down a load of paper towelling first or direct the pipe somewhere that's not going to cover your manifold etc. for obvious reasons.
#19
Posted 15 January 2010 - 06:12 PM
#20
Posted 15 January 2010 - 06:15 PM
#21
Posted 15 January 2010 - 06:23 PM
fair point, but at least it means there's not a fuel blockage between the tank and the carb.Yes but that only means fuel is getting to the carb, not the cylinders.
sorry, just hold the spark plug by the HT lead (don't touch the metal yourself I meant) and rest it against the engine block to earth it.cheers 4 this i will go an try som these thing now althou what did u mean "hold it against the block (obviously nt against the metal)" ? cheers
#22
Posted 15 January 2010 - 06:28 PM
#23
Posted 15 January 2010 - 07:21 PM
#24
Posted 15 January 2010 - 07:34 PM
Edited by samsernie, 15 January 2010 - 07:34 PM.
#25
Posted 15 January 2010 - 07:36 PM
#26
Posted 15 January 2010 - 07:39 PM
Edited by samsernie, 15 January 2010 - 07:40 PM.
#27
Posted 15 January 2010 - 07:40 PM
Edited by Foxy10, 15 January 2010 - 07:43 PM.
#28
Posted 15 January 2010 - 08:01 PM
cheers
#29
Posted 15 January 2010 - 08:08 PM
#30
Posted 15 January 2010 - 08:13 PM
