Another Problem! Rusting From The Inside Of My Arch...
MiniAlex
, Jan 11 2010 08:35 PM
4 replies to this topic
Posted 11 January 2010 - 08:35 PM
Hi again everyone! I was cleaning out my boot yesterday giving it all a wipe down with a cloth. When I put my cloth down the side of the arch (inside) my cloth came out orange
So I had a feel and to me it feels like there is rust there. It's not ontop of the arch, it's deeper than that. I was just wondering if this would effect anything on the MOT? As someone told me that they will check your arches inside and out. I haven't checked the other side because it's behind the petrol tank obviously, but i'm hoping that there will be no rust on the other side... Is it easy to remove the petrol tank to check the arch out?
Posted 11 January 2010 - 08:38 PM
Relatively easy to pop the tank out - best if it's virtually empty - and remove the battery first to avoid nasty shorts and explosions. As long as there are no holes - MOT won't mind - but should treat with rust killer and then paint over. And spray in waxoyl!
Posted 11 January 2010 - 08:43 PM
Thank you
I'll have to get the rust repaired then, it doesn't sound like too much of a job!
Thank you
Posted 11 January 2010 - 08:50 PM
If it rusts to holes - then it's a huge job. Treat it asap. MOT aren't allowed to move carpets etc - never mind petrol tanks!
Posted 11 January 2010 - 08:52 PM
Hahah ooo that's good
Everywhere else is fine. I will do it asap. I've let my dad know that i've got rust there and he said we will do it asap before it starts to get bigger
There are no holes at the moment. I checked around there a while ago, and it wasn't rusting. So I doubt there will be that much!
