Big Order Need A Few Opinions
21 replies to this topic
#16 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 13 January 2010 - 12:05 AM
i find mini spares site hard to use
#17 danrock101
danrock101
  • 2,478 posts
Posted 13 January 2010 - 12:09 AM
so do I, I havn't had any problems with minisport, their site is alot better imo
I tried to buy a exhaust from minispares but some of the staff came across as rude so rang minisport and they were a great help, probably luck of the draw tho
Edited by danrock101, 13 January 2010 - 12:10 AM.
#18 R1minimagic
R1minimagic
  • 4,660 posts
Posted 13 January 2010 - 12:26 AM
I agree, the Minisport website is a lot more user friendly and easy to navigate but that's the only thing i use them for, i never buy anything off them!
They also don't have anything like the info or parts inventory that Minispares have.
#19 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 13 January 2010 - 12:29 AM
12H865KIT Oil Pressure Valve and Spring Kit 1
£1.85 £1.85
R33636 Piston Ring Set - for 998cc Dished Circlip type Pistons 1
£51.59 £51.59
KENMD256K Kent Camshaft Kit - Mild Road 1
SURCAM2 Refundable Kent Camshaft Surcharge 1
Option - Oil Pump Drive: Slot Drive - KENMD256MK 1
£176.19 £176.19
M3314 Glacier Main Bearings - 998/1098 - A+ 1
Choose Size:: M3314LBStd
£33.72 £33.72
B4302 Glacier Big End Bearings - 998/1098/Cooper 998/Cooper S 1
Choose Size:: B4302SAStd
£17.74 £17.74
W2122LSTD Glacier Thrust Washer for 998cc/1098cc/Cooper 998cc 1
£7.43 £7.43
12G793 Mini Sport Oil Pump - Peg Drive - 850/1000/1100cc 1
£10.88 £10.88
C-AJJ3323T Mini Sport Duplex Timing Gear & Chain Set 1
£18.06 £18.06
12G2621OE Genuine Timing Chain Tensioner Pad 1
£3.41 £3.41
GWP134 Genuine Water Pump - High Capacity - inc bypass tube 1
£12.93 £12.93
GEG202 Engine Gasket Set - 850/998/1100cc 1
£10.10 £10.10
GEG102 Head Gasket Set - 850/998/1098cc - Copper 1
£9.68 £9.68
12A1950 Rocker Shaft, standard 1
£7.44 £7.44
VALVAG50911 Steel Valve Guides - Standard - Set of 8 1
£8.12 £8.12
ADU4905 Valve Stem Oil Seals, set of 4 2
£1.42 £2.84
C-AHT54 Centre Oil Pick Up Pipe 1
£24.59 £24.59
thats what i need
#20 Pauly
Pauly
  • 4,213 posts
Posted 13 January 2010 - 10:44 AM
The oil pump should be a slot drive for the kent range of cams (its the most common drive). Rocker shaft should go again, centre oil pickup will involve stripping part of the gearbox and if its not going to be a permormance engine and your not rebuilding the gearbox I wouldn't bother with one.
Dont need to run a tensioner with a duplex timing kit.
I would say if your not having the head modified then the cam would be a waste, because the cylinder head is the most limiting factor for performance in an a-series engine.
Thats my opinion anyway.
Edited by Pauly, 13 January 2010 - 10:48 AM.
#21 sovenmini
sovenmini
  • 191 posts
Posted 13 January 2010 - 12:14 PM
i have used minisport lots and had nothing but problems with them, minispeed are good as long as you get someone good on the phone, mini spares are good and seem very halpful.
#22 JoneseyBoy
JoneseyBoy
  • 808 posts
Posted 13 January 2010 - 04:55 PM
im confused who to go with you are all sayin so many different place to go.
and surely if im doing a full rebuild i should change everything ?
