Unwanted Debumpered Ass!
yeti21586
, Jan 14 2010 04:13 PM
9 replies to this topic
Posted 14 January 2010 - 04:13 PM
Right ive got a 79 and the person who owned vini before me depbumpered him front and back. and while i like the look of a debumpered front end i dont like his bum and as im going to be stripping him down completly and removing rust i thought its a perfect opotunity to replace the rear bumper
so what i need to no is what do i need to buy to fit the bumper???
cheers
YetI
cheers
YetI
Posted 14 January 2010 - 04:18 PM
unfortunately the rear bumper lip is a combination of three panels, the rear panel, the rear valance and sandwiched in between the boot floor...
I would say the quickest thing to do is not try an put the seam back on but mount the bumper onto some small angle brackets so it gives the impression of being 'all there' but in actual fact is just a cosmetic addition...
Posted 14 January 2010 - 04:20 PM
Boot Hinge Panel
Theres someone on here
CobraV8?
He put a bumper on without a hinge panel , but im not sure
EDIT: BEATEN TO IT
I THINK YOU WOULD BE ABLE TO DO WHAT GUESSWORK WAS SAYING
YOU WOULD NEED TO BUY THE HINGE PANEL , 9.5" BOOT FLOOR REPAIR AND A REAR VALANCR BUT IT WOULD BE QUITE EXPENSIVE JUST FOR THE BUMPER
CobraV8?
EDIT: BEATEN TO IT
Edited by xBR4DLEY, 14 January 2010 - 04:22 PM.
Posted 14 January 2010 - 04:25 PM
so you reckon welding 4 or 5 or more brackets along the back??
and im thinking of a carbon fibre bumper so its gunna be light
i shall keep this in mind
cheers
cheers
Posted 14 January 2010 - 04:26 PM
The normal bumper only bolts on in 3 places.
JD
JD
Posted 14 January 2010 - 04:54 PM
lol didnt no that so 3 brackets then
Posted 14 January 2010 - 07:53 PM
Yep my car was deseamed front and back - and like you I wanted bumpers back on. All I did was make some angle brackets out of light steel and bolted them to the bumper, positioned the bumper where it should be, and then riveted the brackets to the body with two rivets per bracket. You could probably do better with rivnuts and bolts.
Also.. I put a piece of rubber heater hose over the brackets to make the bumper sit tight against the body, seemed to stop it vibrating about.
Posted 14 January 2010 - 08:00 PM
front bumper lip riveted to rear of car
dave
dave
Posted 14 January 2010 - 08:06 PM
or weld the lip on the rear but it is a water trap. three nicely made brackets from aluminium or stainless could be a nice way
Posted 14 January 2010 - 08:47 PM
yeah am swaying towards welding 3 brackets on and then fitting a carbon bumper on the back yummy
