Heated Rear Window Not Working!
10 replies to this topic
#1 cyber_dog
cyber_dog
  • 12 posts
Posted 17 January 2010 - 05:51 PM
Hey
Can anyone help! My heated rear window is not working! I kinda need it given the pants weather we're all experiencing at the moment.. I was wondering if it is as simple as changing a fuse or switch! Has this happened to anyone else?!
Thank you!! :D
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 17 January 2010 - 05:56 PM
Try posting in the technical section :D
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 January 2010 - 06:10 PM
any power at the window ?
#4 nicksuth
nicksuth
  • 1,631 posts
Posted 17 January 2010 - 08:59 PM
It's probably damaged elements? I have only "one" element working and when looking closely at the others I can see tiny breaks probably done when cleaning the back window? I have bought a repair kit which is basically some silver type paint and a template - Link
PS - I have not got around to trying it yet but will post results when I do :D
#5 MiniAlex
MiniAlex
  • 734 posts
  • Local Club: Mini's N Oatcakes
Posted 17 January 2010 - 09:09 PM
Hi.. I have just had to repair my heated rear screen. There was only 2 bars working out of the 5 I think it is. I got some silver paint from this old car shop. Called Electro Connector. It was £10 but it was well worth it!! There is most probably a connection problem. When I looked closley at mine, where it plugs in (where the lead attatches to the screen) it was alkl corroded there and nasty. As soon as I put the paint on it worked fine again. If there is a crack then the connection won't be made so it just results in the screen not working.
Try putting some of the paint on it, if it doesn't work then you might not have any power to the back screen. Make sure you have power though first before you buy the paint!!
Let us know how you get on.
Hope this helps
Alex :D
#6 MiniAlex
MiniAlex
  • 734 posts
Posted 17 January 2010 - 09:10 PM
Nick that's the stuff I have got!
It works really well :D My dad said that he had used it years ago!
#7 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 17 January 2010 - 09:16 PM
I've seen that product at Halfords.
#8 nicksuth
nicksuth
  • 1,631 posts
Posted 17 January 2010 - 09:17 PM
Good to hear it works !! I'll give it a go later this week. I guess you need a steady hand though ??
#9 IFlingPoo
IFlingPoo
  • 213 posts
Posted 17 January 2010 - 09:31 PM
It works really well :( My dad said that he had used it years ago!
Only if you want straight lines! :D
#10 MiniAlex
MiniAlex
  • 734 posts
Posted 17 January 2010 - 09:50 PM
It works really well :thumbsup: My dad said that he had used it years ago!
Haha :) I haven't .. but you get a little template in the box to help you!
Good job I didn't have to use it on the thin lines. It was on the bigger area by the plug that had gone so I was lucky.
I never knew they sold it in Halfors!
Still it was only £10 :P
#11 cyber_dog
cyber_dog
  • 12 posts
Posted 18 January 2010 - 04:39 PM
Nice.. Thanks for all yor quick responses! There is power going to the rear window which is good but i also have tiny breaks so its probably that like you said! I cant see any corrosion around the car-to-window connectors so ill buy some of that magic pant and try that out for size! Thanks again for your help peoples :D
