Engine Wont Start
Posted 17 January 2010 - 06:38 PM
it turns over but wont start up, dont even get any coughing. theres a spark and theres fuel. ive checked the firing order which was wrong so sorted that out. there must be fuel getting into engine from carb as the garage stinks of petrol now.
im stuck now, anymore ideas, possibly carb needs a rebuild?
Posted 17 January 2010 - 07:08 PM
Posted 17 January 2010 - 08:00 PM
firing order is 1342 anticlockwise around the cap, no1 being the passenger side bore. no1 is connect at the dizzy at 1clock. thats correct isnt it?
hopefully tomoro night will all go swimmingly and it will fire up with a bit of play of the mixture screw.
Posted 17 January 2010 - 08:02 PM
well me being a bell end connected the fuel line to the wrong inlet and think it flooded, ive done the above and left the plugs out to try and evapourate some more over night, as it wunt start still when i sorted the fuel line out so it must still be to flooded.
Yep, should fire if nothing else is a miss.
Posted 18 January 2010 - 09:26 PM
i tryed taking servo off manifold and spraying easy start down and the engine tryed to kick into action but then i kick a big flame back at me, my first thought was that may be carb isnt actually releasing petrol despite getting it??????? any good ways of testying for this?
a friend suggested though that it could be the timing out and as a result kicked the flame out. so i set piston no1 to tdc by using the rockers on no4 (i was going to use the pulley but its miles out compared to the rockers way,the notch was past tdc prong) the rotar on dizzy pointed to 1 clock so the dizzy cant be that far out so should start still?
Posted 18 January 2010 - 09:31 PM
Edited by Pauly, 18 January 2010 - 09:31 PM.
Posted 18 January 2010 - 11:08 PM
incase it is 180 out, how do i go about solving this? can i do it without taking out the whole dizzy as id like to avoid this incase i drop anything into gearbox
one other thing i have a feeling it might be doing is sparking after its hit tdc could that be the problem?, so if i go clockwise with the dizzy will it give it advance?
Posted 18 January 2010 - 11:27 PM
undo the dizzy clamp and pull it out. then get a long bolt, screw it into the dizzy dog drive and gently pull it out. twist it 180 and gently replace.
i'm afraid its trial and error on finding the right bolt, i struck lucky with the first one i picked so dont know the size.
have you tried turning the dizzy gently each way while firing the engine up, i've known a car where the timing was only slightly off that wouldn't fire. a quick tweek and boom, the car fired up first time, every time
Posted 18 January 2010 - 11:29 PM
and now at every show shifty gets under the bonnet and its fires up everytime. hahaha sorry shifty couldnt resist that one!
Posted 18 January 2010 - 11:40 PM
