I have searched through all of the sound deadening topics, but I still have some questions I'd like clearing up. Basically, my mini is VERY loud inside; it's not much fun driving it like this. I want to add sound deadening to kill engine / exhaust noise on the inside, not to improve my music quality. I need some advice.
1. I need to replace the insulation on the bulkhead / firewall / dash area, as half of it has been removed due to it holding dampness. (which will now be causing part of the noise issue) What is the best stuff to replace this with? (original or aftermarket?)
2. Where are the key areas on the mini which benefit from more sound deadening? The floors still have the original bitumen stuff on, but there is no felt layer betwean that and the carpet.
3. What to use? I've looked at dynamat etc, but this doesn't look to be cost effective for me. I'm not looking for something to improve music quality, just block engine / exhaust / road noise. Some people suggest a couple of layers of flashing tape, but others say it's useless. Any advice as to a reasonably priced sound deadener?
I know this is partly down to my spec: (998, k&n cone filter, cooper freeflow manifold, rc40 straight through 1.75 exhaust, no silencer, megajolt ignition, solid subframe mounts) but this is all staying (would subframe mounts effect the noise that much?), as the car sounds nice from the outside, and performs well.
Thanks for reading,
JJ
