Correct Length Of Tie Bars
17 replies to this topic
#1 Minitrio
Minitrio
  • 420 posts
Posted 17 January 2010 - 09:34 PM
Model:MPI
Year:1997
What is the correct length for tie bars? Need to set adjustable ones.
Anyone know?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 January 2010 - 10:15 PM
there isn't one thats why they are adjustable
there is on the other hand a angle you need to set your caster to, the adjustable tie rods alter this angle
#3 R1minimagic
R1minimagic
  • 4,660 posts
Posted 17 January 2010 - 10:17 PM
You mean you want the length of the standard ones?
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
There is!!
Have a dig around the minispare site, the size is on there somewhere.
#5 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 17 January 2010 - 10:19 PM
there is a correct length for a std tie bar but for some reason the search engine doesn't do it's job so i can't find it for you.
I know icklemini has posted it up before, you just need to find it..
#6 Tim1970
Tim1970
  • 394 posts
Posted 17 January 2010 - 10:28 PM
As per the guide that came with my minispares adjustables.
Standard length is 14 5/16" from the front of the locating washer to the nearest edge of the bolt hole.
Also one rotation adjusts the length 1/16" which equates to just over 1/2 a degree castor.
Although i wouldn't take this for granted even if they are the minispares ones.
Always best to get the castor set properly after.
Edited by Tim1970, 17 January 2010 - 10:29 PM.
#7 Minitrio
Minitrio
  • 420 posts
Posted 17 January 2010 - 10:31 PM
Yeah tried the search engine first, but it didn't come up with it, hence asked the question.
I was looking for the standard length. Sorry should have worded the question a bit better.
Will have another look, because i remember someone posting it on here before so will look for icklemini post and then try minispares.
Will let you all know when i find it and let you all know.
#8 Tim1970
Tim1970
  • 394 posts
Posted 17 January 2010 - 10:32 PM
:thumbsup:
#9 Minitrio
Minitrio
  • 420 posts
Posted 17 January 2010 - 10:34 PM
Excellent, Thanks Tim.
That was exactly the info i'd seen before, now a quick trip out to the garage! MOT in the morning!!
#10 Tim1970
Tim1970
  • 394 posts
Posted 17 January 2010 - 10:36 PM
No problem.
Good luck with the MOT mate.
#11 MRA
MRA
  • 7,607 posts
Posted 17 January 2010 - 11:27 PM
It is 1/18" as th epitch is 18tpi :thumbsup:
#12 Tim1970
Tim1970
  • 394 posts
Posted 17 January 2010 - 11:51 PM
Cheers. That does make more sense.
Not sure why the minispares guide says 1/16"?
Edited by Tim1970, 17 January 2010 - 11:52 PM.
#13 MRA
MRA
  • 7,607 posts
Posted 18 January 2010 - 01:13 AM
pass :thumbsup:
#14 icklemini
icklemini
  • 2,982 posts
Posted 03 February 2010 - 12:27 AM
squish of the rubbers?? :mrcool: :(
#15 MRA
MRA
  • 7,607 posts
Posted 03 February 2010 - 06:40 AM
squish of the rubbers?? :) :(
Not sure what you are saying here ? are you referring to the 1/16th instead of the 1/18th per bar revolution ??
If the rubbers are "squished" and you take a measurement, then adjust by one revolution then it will have changed the length by 1/18" as the "squish" is going to be the same for either instance.
Somebody at MS has confused pitch with fractions :mrcool:
