which one is best remote or rod change? if remote will i be able to fit it into a 1988 car?
cheers guys
Remote Or Rod Change
Willcox
, Jan 18 2010 06:03 PM
4 replies to this topic
Posted 18 January 2010 - 06:03 PM
Posted 18 January 2010 - 06:05 PM
Rod is the best , they changed the gearboxes from Remote to Rod change as they were better
Also no you won't be able to put it in as they have a different gear linkage (I think)
Posted 18 January 2010 - 06:09 PM
cheers, its just i have a rod and remote box just wondered which one is best and if the remote would actually fit
Posted 18 January 2010 - 06:25 PM
Yes and no... on all fronts...
A well sorted remote is every bit as good as a rod, and can actually provide a more positive gear change... ( plus no lift for reverse ) however the cases are weaker in design so not so good for high powered applications..
Would it fit into a 1988 mini, with a little bit of modification to the tunnel where the gear lever is located, then yes.
Simplest thing is to use a rod change, it's what the car you have was designed to use.
Posted 18 January 2010 - 06:39 PM
cheers guess works ill just rebuild and use the rod box then, thanks for the help
