Getting Choke Cable Back In
6 replies to this topic
#1 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 19 January 2010 - 12:31 PM
A bit embarrased to ask about this, but here I am, looking at my new, shiny ratchet type choke cable that I just got. Played with it a little bit, then I pulled the cable a little bit too far and I can't push it back in. So I pulled the whole cable out of the casing and tried to push it in again, but it won't go.
What can I do to put it back in?
This is truly a :thumbsup: moment....
Thanks,
Aria
#2 IainR
IainR
  • 251 posts
Posted 19 January 2010 - 12:41 PM
Lightly oil or grease the inner cable, offer it up to the outer and twist it slowly in the direction of the grain of the wire strands as you insert the end, keep twisting in that one direction only and feed it through - make sure the outer is laid out straight/flat. If you rotate the inner cable "against the grain", so to speak, the ends of the strands will catch and possibly unravel.
#3 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 19 January 2010 - 12:57 PM
Okay.... thank you so much for the tips!!! :thumbsup:
#4 finch661
finch661
  • 2,339 posts
Posted 19 January 2010 - 01:19 PM
sorry to hi-jack, but can ratchet choke cables be used to replace the twist&lock ones?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 January 2010 - 01:24 PM
not directly as the mounting hole is a different shape, but a bit of bodging ( or a replacement switch facia ) could be done...
As for putting oil down it, the choke cable is not so bad, but under no circumstances do this with an accelerator cable, oil and grease collects dust which can cause a cable to stick, not clever on the accelerator...
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 19 January 2010 - 01:36 PM
Although interestingly enough I used to work for an OEM cable manufacturer and they greased every cable prior to insertion into the outer assembly - even ones using teflon liners.
#7 Aria Aradhea
Aria Aradhea
  • 563 posts
Posted 19 January 2010 - 03:37 PM
cable insertion done! :)
Thank you all for the help!!
