3 Stage Paint Jobs...
12 replies to this topic
#1 Bert
Bert
  • 303 posts
Posted 19 January 2010 - 06:36 PM
Anyone here got a 3 stage paint job?
Am looking to get my mini re sprayed but every colour i like is a 3 stage paint process...
Is there anyone with a 3 stage paint done?
Any problems been found so far? like, if u've painted it and had to change a panel for whatever reason, how hard was it to match the paint again?
cheers
#2 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 19 January 2010 - 06:51 PM
depends some say 3 stage but just means needs a ground coat but only for coverage others are 3 stage where the second stage is a tinted clear where if more coats are applied then the colour gets deeper? if its later type then yes can be a real pain to get a match if repairs are needed. can be done but usually shows to a degree. What is the colour?
#3 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 19 January 2010 - 06:59 PM
mine came out well.
the compressor did pick up water on a very small area of the clear coat and that spoiled the finished in a small part of the car, not enought for everyone to notice, but i know its there,
#4 Bert
Bert
  • 303 posts
Posted 19 January 2010 - 07:08 PM
2nd one, there is a few colours.
Initially i bought Candy apple red...love this colour, but the original painter said he wouldnt do it cause he knew the mini would rust and matching it would be a coont...
every other colour i've looked at is the exact same tho, 3 stage...from Nissan R34 Gun metal grey, ford Frozen white, Alfa 8C Competizion red...etc
it's proving a rather pain in the aris...
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 19 January 2010 - 07:19 PM
Did any of the painters explain what this "3 stage" process is?
Most older paints are recognised as 'base coat and clear' meaning colour coats plus laquer. These days with water based paints it is very much the same.
So i can only see that 3 stages are: 1) primer, 2) colour/base/metallic 3) laquer / top coat.
As for matching colours in the future - any painter worth anything can match paint / adjust re fade (most paints have 3 - 5 shades) or flick the panels surrounding the repair.
I mean how do cars get repaired normally.
Pick a colour and go for it mate :)
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 19 January 2010 - 07:31 PM
By three stage I'm assuming you're meaning a pearl or candy colour? They often have a base colour, then a binder based transparent coat, either tinted or containing pearl, the affect or depth of colour relying on the number of coats applied. Either way all 3 stage paints are a nightmare to match, seeing as you can't blend them like conventional 2 stage metallics, so have to rely on getting an edge to edge match, which is often difficult with even a 2 stage.
Edited by panelbeaterpeter, 19 January 2010 - 07:34 PM.
#7 In-a-mini
In-a-mini
  • 831 posts
Posted 19 January 2010 - 07:38 PM
no a 3 stage paint is 1.metalic/straight base 2.tinted clear then 3.the final clear coat. As said the effect or colour can be altered by the number of coats applied. when repairing a car painted in this way you usually have to mix an amount of paint an spray out what is called a let down panel (not a spray out card) what you do is paint fully with the ground basecoat then mask off in strips paint one coat of tinted clear remove a strip then another coat repaint until panel is fully painted. what you end up with is a panel with gradually darker stripes down it. compare this to the vehicle and which ever one is closest is how you have to paint the panels to match. you cannot blend though so edge to edge is how it needs painting.
#8 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 19 January 2010 - 08:43 PM
my response was based upon spraying onto the primed shell
in my case it was a flat base colour, foloewd my the metalic colour and then the clear coat
#9 Bert
Bert
  • 303 posts
Posted 19 January 2010 - 09:08 PM
Aye so u agree it'll be difficult to match...i might just go ahead with it cause i am probably going to punt it before work needs done...unless i get smashed into
#10 Bert
Bert
  • 303 posts
Posted 21 January 2010 - 12:07 AM
mine came out well.
what colour did u get urs? any chance of some pictures?
#11 olliemarc
olliemarc
  • 10 posts
Posted 23 January 2010 - 02:13 AM
cheers
if you are choosing a standard varient of a colour from a factory standard car then if you were to change a panal then they should mix the same varient of that colour for respray, u shouldnt have any problem unless u use a flip or metal flake, always get them to write down what variant of colour they have used because some paints have many and could cost if respraying and tinting to match existing paint
#12 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 07 February 2010 - 09:37 PM
old post i know, but here you go...
#13 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 07 February 2010 - 10:05 PM
its problematic to say the least if you get a doink or scratch - just have to be prepared in your mind that its a big job to sort even minor blemishes.
