Read Lots Of Posts On Moulton Smootha Rides
9 replies to this topic
#1 Hayley
Hayley
  • 293 posts
  • Local Club: 40mmc
Posted 19 January 2010 - 07:47 PM
I just came across some posts offering advice regarding a smoother ride and I know have lots of questions to ask, I got a full smootha ride kit for christmas, but don't know whether its worth fitting after reading peoples experienceof them.
I was recommended them as my ride at the moment is back breaking! I currently have a no name adjustable kit on my original 10 inch wheels, the handling is sharp, but has now become unbearable for my daily drive to work, due to many road humps and pot holes on the way.
Will they make a difference?
Ruin the handling? ( not forgetting its not a racer)
Also, my car sits LOW at the moment, which looks good but isn't practicle, so I don't mind it being raised a little but will the kit raise it considerably more?
(If this has been covered Im sorry........... i could'nt find AN ANSWER)
#2 jaydee
jaydee
  • 8,565 posts
Posted 19 January 2010 - 07:51 PM
Just fit standard rubber cones.
If you want to spend the money and upgrade cones, then go for some red dot cones, smootha ride will become soon like standard multon cones..
#3 Hayley
Hayley
  • 293 posts
  • Local Club: 40mmc
Posted 19 January 2010 - 07:56 PM
[quote name='jaydee' date='Jan 19 2010, 07:59 PM' post='1705962']
thanks but that doesn't really answer my question
#4 jaydee
jaydee
  • 8,565 posts
Posted 19 January 2010 - 08:07 PM
Only thing i can say..red dots will sit a bit higher, and require hi-los to set the correct height.
Raising the car will make your ride less harsh in the city, but dont rise it like a jeep or handling will suffer..
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 19 January 2010 - 08:32 PM
people stop talking junk, smooth ride or standard cones, with adjsuterides, no issue, both will feel lovely comapred to old knackered suspention, along with new shocks and bushes and it will drive like a differant car and for the better to be honest, complinacy is whats needed in a car, not solid as a rock, because we are talking about the uk roads here
#6 Hayley
Hayley
  • 293 posts
  • Local Club: 40mmc
Posted 19 January 2010 - 08:37 PM
Thanks that seems more like the answer I was looking for!
If anyone has any advise along these lines I'd be grateful
#7 lolipop
lolipop
  • 151 posts
Posted 19 January 2010 - 09:10 PM
Fitted Moulton SmoothaRides along with Mini Sport adjusta-rides to mine last April,and found them great,ride is a lot smoother,minor road defects are barely noticeable,handling is barely any different.Only downside was the front rideheight was high for a while until the cones settled.I would recommend you fit them for a daily driver like mine,i'm sure you will be pleased you did.
#8 Hayley
Hayley
  • 293 posts
  • Local Club: 40mmc
Posted 19 January 2010 - 09:24 PM
Cool, looks like I'll fit them then! Would I benefit from getting some better shocks than the ones supplied with the kit?
#9 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 20 January 2010 - 01:25 PM
For the Smootharide system to work properly, you should really use the standard type shocks (dampers) they supply in the fit.
Otherwise what would be the point should you fit uprated firmer/adjustable ones? You might just as well fit standard rubber springs/cones then.
#10 Hayley
Hayley
  • 293 posts
  • Local Club: 40mmc
Posted 20 January 2010 - 07:30 PM
I see your point, i wsn't neccessarily thinking firmer when i say uprated, i wondered whether there could be better oil shocks than the ones supplied?
