Walnut Wood Grain Flim
15 replies to this topic
#1 karlos_junior
karlos_junior
  • 176 posts
Posted 20 January 2010 - 03:44 AM
Im looking for some kind of walnut transfer / film to go over a dashboard Im working on. anyone know where I can get that sort of thing from?
#2 RowenBlaineSkinley
RowenBlaineSkinley
  • 641 posts
Posted 20 January 2010 - 03:56 AM
hmmm as you are living in new zeland, not sure if you have a homebase or B&Q so i would suggest a DIY store im sure theyld sell it
#3 roofless
roofless
    Sticker Pimp
  • 7,216 posts
  • Local Club: central minis
Posted 20 January 2010 - 11:38 AM
I can supply wood grain effect vinyl - varying grades and quality, from £7.00 per metre, to £20.00 per metre
just boils down to how much you want to spend, and how good a quality of finish you want. :dozing:
the cheaper range is on the picture below. :dozing:
#4 karlos_junior
karlos_junior
  • 176 posts
Posted 20 January 2010 - 08:52 PM
thank you.
trying to find like a burr walnut.
#5 tommy13
tommy13
  • 878 posts
Posted 20 January 2010 - 09:33 PM
Have a look at this
http://cgi.ebay.co.u...=item2c4fb663e8
#6 karlos_junior
karlos_junior
  • 176 posts
Posted 20 January 2010 - 11:28 PM
PERFECT.
thank you
#7 MiniMonty
MiniMonty
  • 1,802 posts
Posted 20 January 2010 - 11:42 PM
Is that right ? 450mm x 2 meters for £3:49 ?
Looks like a decent deal. Might have to have a couple of rolls of that
for tarting the house up !
#8 spadge123
spadge123
    Starting My Mini Up
  • 1 posts
Posted 21 January 2010 - 04:11 PM
www.wallnutdash.co.uk
#9 karlos_junior
karlos_junior
  • 176 posts
Posted 22 January 2010 - 12:59 AM
nice but that link dont work.....just n extra L!
Edited by karlos_junior, 22 January 2010 - 01:00 AM.
#10 karlos_junior
karlos_junior
  • 176 posts
Posted 22 January 2010 - 01:03 AM
also I dont think they sell just the film...shame because was sort of what I was after...
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 22 January 2010 - 02:38 AM
Is there a particular reason you wish to use vinyl instead of wood veneer?
#12 karlos_junior
karlos_junior
  • 176 posts
Posted 25 January 2010 - 01:10 AM
Simply because I cant find a nice suitable venner that is workable..I may have the wrong idea tho of what a veener is.....
I want to make the dash out of a simple MDF but cover it in a walnut finish..
I had some sicker like stuff you heated at stuck down that I cant get anymroe((see attachec its around the gauges))
Attached File  DSC_0126.JPG   987.47K   25 downloads
Im hoping to do the whole dash like attached but replaing the leather part with a woodgrain...
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 25 January 2010 - 03:59 AM
I was just curious.
If you're planning on fitting a laminate to surfaces with compound curves then vinyl will certainly be easier. Be sure to post pictures of your dash when the project is completed.
#14 distrofoil
distrofoil
    Starting My Mini Up
  • 1 posts
Posted 31 March 2016 - 01:41 AM
For Dashboard application,I think you can take a try a method of"water transfer".
Unfortunately,we do another "heat transfer foil or hot stamping foil".
www.dsofoil.com
www.distrofoil.com
#15 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 31 March 2016 - 12:30 PM
I did this with my old water damaged dashboard. I went to a local vinyl sign maker who found a suitable walnut design on the internet and downloaded it and printed it off. It looks fine and is a cheap fix until such time that I decide to replace with an original one in good condition.
