Engine Nuts, Bolts, Fastners.. Help!
Posted 20 January 2010 - 10:17 AM
Hope someone can help!
Posted 20 January 2010 - 10:45 AM
It might make better economical sense to buy a tap and die set, this way you can clean the threads up on the existing nuts and bolts, get a wire brush on them to clean the outsides and then they'll be good as new.
The tap and Die set also gives you a little security knowing that if any of the fixings get a little damaged on removal you can salvage them and use them again.
Posted 20 January 2010 - 10:54 AM
There are a few sets available like subframe kits etc,.. But be warned that although you'd think it would be cheap - replacing most of the nuts and bolts on a mini is actually very expensive and would easily cost hundreds....
Yeah i'm only looking for the engine ones, which quite a few of were missing!
Posted 20 January 2010 - 10:55 AM
Local nut and bolt shop will sell in bulk, much cheaper and I mean a NUT AND BOLT shot, not B&Q, not a DIY shop. I mean a shop that sells fasteners and a few tools.
Which in my case is Westgate Fastenings.
Posted 20 January 2010 - 11:08 AM
Posted 20 January 2010 - 12:59 PM
Posted 20 January 2010 - 01:13 PM
UNF - nut 'n bolt & threads in steel
UNC - threads in cast components e.g. the gearbox casing.
Metric - newer generic parts
Those aren't absolute rules & there are others, BA on instruments, BSP, NPT....
Posted 20 January 2010 - 02:41 PM
The Moss catalogue, and website in fact, are only really any good for later cars from about 1984 onwards in my experience. Somerford has the best website for this type of search frankly and offers the greatest detail with a simple interface. Mini Spares and SC Parts both have a very good parts catalogue. The Somerford and Moss websites are handy once you have the part number from a book in that you can find out the thread and size details for a fastener from its part number using their sites. Mini Spares have that for some parts but not all. Part numbers are normally universal because they come from Rover (BL, BMC etc.).
