Hilo's: Easy To Install
7 replies to this topic
#1 minu
minu
    Starting My Mini Up
  • 2 posts
Posted 21 January 2010 - 10:27 PM
Model:piccadilly
Year:1986
In the process of rebuilding and wonderd if HiLo's need extra parts or is it just a straight swap?
Heres what im thinking of getting: http://www.minispare...mp;tc=1#submenu
#2 R1minimagic
R1minimagic
  • 4,660 posts
Posted 21 January 2010 - 10:51 PM
It shows at the bottom of that webpage the other parts that may be required. I would put new knuckle joints on anyway and maybe new cones if yours are old and knackered.
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 22 January 2010 - 07:16 AM
and you will need a cone compressor on the front
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 22 January 2010 - 09:11 AM
Should take you a day to do and front are more involved as you need to remove top arm.................. :teehee:
#5 minu
minu
    Starting My Mini Up
  • 2 posts
Posted 22 January 2010 - 03:54 PM
Sweet. Sounds like a plan :(
#6 aaron876
aaron876
  • 228 posts
  • Local Club: Need To Join One
Posted 22 January 2010 - 09:53 PM
Just Smash the old trupet out with a hammer, i done mine yesterday, and saves money
also only took me half hour to do both sides
thought it mite save you A Lil bit of cash mate
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 22 January 2010 - 10:15 PM
You only need top arm out if fitting new cones!
#8 spennyy2k
spennyy2k
  • 111 posts
  • Local Club: south lancs mini owners club
Posted 22 January 2010 - 11:05 PM
i did mine in a night, cut the old trumpets up they will fall out, wind the hi-los to the smallest hight (if that makes sence) the rears go in easy , the fronts where a bit stubbern but went in without a compressor ... also bought mine here .. think i payed £50 for the set + knuckles iirc
