Cream In Oil But Dont Think Its Head Gasket
Posted 23 January 2010 - 09:07 AM
I recently found i had an oil leak from the rocker cover gasket, so i went and got a new one from the local shop, couple of weeks later i find i have some cream in my oil, so i checked the water to see if it could be headgasket and the water had not changed. Cleaned it off and checked it yesterday to find a lot of cream, even in the rocker cover when i took it off it was plastered in creamy stuff. But again i have not lost any water. When i looked at the rocker cover gasket it looks like one side was not put it down level so like on one side of it half the gasket is compressed where the rocker cover has sat flush and half was untouched. The gasket was also very wet.
Do people think the cream could just be where i have not put the gasket on right and water has come in from the front and mixed with the oil or something different. The water in the oil has to be coming from somewhere but its not from my water tank and there is no oil in the water.
The car has not overheated, it has not lost any power and is not smoking badly
Any ideas?
Posted 23 January 2010 - 09:11 AM
Posted 23 January 2010 - 09:15 AM
Posted 23 January 2010 - 10:10 AM
Posted 23 January 2010 - 10:11 AM
Posted 24 January 2010 - 12:07 AM
Are all the engine breathers attached?
Posted 24 January 2010 - 10:37 AM
Posted 24 January 2010 - 11:50 AM
the way to check is a compresion check.
Posted 24 January 2010 - 11:55 AM
Edited by bmcecosse, 24 January 2010 - 03:03 PM.
Posted 24 January 2010 - 02:51 PM
apparently the duckhams (Green) oil is quite prone to this, if your using it swap to something else.
I've not had problems and I've been using Duckhams Q Classic 20W/50 oil (which is no longer green and is now out of production since Castrol own Duckhams and have introduced their own classic oil) for years.
Posted 27 January 2010 - 02:51 AM
It's certainly nothing to do with the rocker cover gasket! It's because of lack of crankcase breathing - not taking away vapours that by=pass the piston rings. Get hold of a rocker cover with a breather - and connect it to the carb inlet. I would also fit a higher temp thermostat (88) - and blank off part of the grille in winter to raise underbonnet temp.
I agree. My car had the same issue - and it was during summer. Putting a rocker cover that had a breather pipe (in my case into a catch can) solved the issue.
Posted 27 January 2010 - 08:13 AM
Posted 27 January 2010 - 11:05 AM
Posted 27 January 2010 - 12:40 PM
Edited by liirge, 27 January 2010 - 12:42 PM.
