Carb Lifting Pin
13 replies to this topic
#1 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 23 January 2010 - 03:33 PM
Hi all
Theres supposed to be a piston lifting pin on my carb somewhere, but i cant for the life of me find it. Its an SU carb on a 1989 designer. Can anyone help? Thanks
#2 2lrminivan
2lrminivan
  • 276 posts
Posted 23 January 2010 - 03:38 PM
as you look at the carb it will be on the left i think toward the back edge under the piston/dash pot
are you sure it should have one.
why do you need to find it?
Edited by 2lrminivan, 23 January 2010 - 03:38 PM.
#3 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 23 January 2010 - 03:41 PM
We've fitted a stage one kit, and just till we can get it on a rolling road i need to get it running ok-ish. Following haynes the procedure involves lifting the piston... Or is this just typical Haynes (un)accuracy?
#4 2lrminivan
2lrminivan
  • 276 posts
Posted 23 January 2010 - 03:47 PM
as far as i no u only need to lift it to make sure the piston is not stuck but i might be wrong.
what is the procedure then ?
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 23 January 2010 - 03:48 PM
Haynes for once is CORRECT! But - not all SUs have the handy little pin. In which case - use a small thin blade screwdriver in the front of the carb - and lift the piston with that. Just an 1/8" inch is all!! Otherwise - just twiddle the mixture back and forth until you get the smoothest/fastest idle. Generally RR is waste of time/money - since most operators have little idea of the Mini or the SU carb. If you have the AAA needle in there - and set the mix as above - then road test it - switch off after a goodish run under power - and pull a plug out. Should be light tan colour - if white it's too weak - if black it's too rich. You should also advance the ignition until you get a little pinking under load - then take it back slightly so it's just 'not quite' pinking. That's the best you can do - unless you know how to change the advance curve in the dizzy.
#6 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 23 January 2010 - 03:50 PM
Ahhh ok that would make sense, thanks. I think once the idle is set your'e supposed to lift the piston and listen to see if the revs drop, rise or stay the same. But i'm not sure as i dont have the manual with me right now. Think i might get it sounding/ticking over right and then look at the mixture.
#7 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 23 January 2010 - 03:52 PM
Thats just what i needed, many thanks! I'm still not sure where to lift the piston though, can you help further?
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 23 January 2010 - 03:55 PM
Just lift it with tip of the screwdriver! It has to be small - to avoid upsetting the air flow and spoiling the result.
#9 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 23 January 2010 - 03:56 PM
Great! Will give it a bash tonight
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 23 January 2010 - 03:58 PM
NO! Don't 'bash' it - just a gentle lift!
#11 jinjrich
jinjrich
  • 543 posts
  • Local Club: YMMOC
Posted 23 January 2010 - 04:01 PM
Hahaha got it! :lol:
#12 Ethel
  • 25,935 posts
Posted 23 January 2010 - 04:02 PM
Even if the operator has never seen an SU they would still be able to monitor the AFR under load and see if you're running lean enough to melt your engine. I do agree there less point on splashing out on a RR session for a car that is almost standard and it would be nice if the operator was well versed in the black art of needle profiling.
Lifting the pin should cause the revs to rise briefly before settling back down. If they rise and stay up it is too rich. If it stutters on the point of stalling it's too lean.
#13 bmcecosse
bmcecosse
  • 9,699 posts
Posted 23 January 2010 - 04:04 PM
If it's an AAA - it won't be too weak - and the plug check will confirm.
#14 stormintrooper
stormintrooper
  • 2,072 posts
Posted 23 January 2010 - 05:11 PM
my local guy that does RR's can do needle profiling too :lol:
