Crank Shaft, And Bearing Problem?
Posted 24 January 2010 - 08:09 PM
regards mike
Posted 24 January 2010 - 08:17 PM
Hi Mike,hi, i have a little problem rebuilding my block i have the new main bearings, everything has been cleaned correctly and everything is been put on correctly and i have then oiled the top of the bearings, tightened the bolts up to the correct talk settings. i thought the crank should still move by hand. because mine will not move at all.
regards mike
Has the crank been re-ground at all or is it all standard. I take it you have oiled the mains, fitted new main shells to the caps, fitted new thrust bearings, everything well oiled, placed the crank in, fitted the main caps & torqued down squarely. It should still turn freely. if not then something is pinching up. Have you checked you have the correct main bearings, I ordered a standard set before & got sent a +.010" set.
Posted 24 January 2010 - 08:22 PM
Posted 24 January 2010 - 08:28 PM
Sounds like the main caps are pinching the crank up, slacken off the bolts and see if it turns. Did you fit the center cap with the tabs on the same side?
can you explain further on what you mean about the centre cap please,
regards mike
Posted 24 January 2010 - 08:50 PM
If new rings have been fitted and there is a fresh hone on the bore, there is no way you will turn the engine by hand, and is the reason you should build the engine without rings first. Twice the work, but then you know for sure that any tightness is purely down to the rings
Posted 24 January 2010 - 09:13 PM
check each big end still has a little side movement, thus indicating they are ok, also ensure that all main bearing caps have all the numbers reading the same way.
i havent even got new piston rings yet the pistons arent on everything seem right the caps are 030 and the crank shaft been ground to that and 030 main bearings everything seems fine just will not move atall.
Posted 24 January 2010 - 09:25 PM
Posted 24 January 2010 - 09:37 PM
Posted 24 January 2010 - 10:46 PM
Edited by bmcecosse, 24 January 2010 - 10:56 PM.
Posted 24 January 2010 - 10:49 PM
Posted 25 January 2010 - 03:49 PM
I have just recieved word from Crewe engineering that the bearing caps are the wrong ones potentially!!
Do know how this can be, anybody what number caps should go with a 1275 A+!
I bought this a short kit, Crewe had done most of the work but not seen the caps!
Posted 25 January 2010 - 04:23 PM
Hi,
The numbers are irrelevant really - you either need the correct caps for that particular block (ie not any old 1275 A+ caps) or else you will need to get any replacement caps machined and line bored to match them with the block.
Posted 25 January 2010 - 05:10 PM
If you bought a block non-matching caps you were 'done over'. Demand your money back!
If you are in trouble I may have a short A+ engine in good condition for a sensible price. Let me know if I can help.
Edited by Cooperman, 25 January 2010 - 05:10 PM.
Posted 25 January 2010 - 06:11 PM
