A Serise To A+
12 replies to this topic
#1 valve bounce
valve bounce
  • 694 posts
Posted 24 January 2010 - 09:57 PM
rite the my mini has a 998 a serise in it which need a cylinder resleveing and skiming but have been offered a 998A+ bottom end crank, block, pistons so what im thinking is can i use the a serise crank(already been reground) in the A+ block, pistons and rods other than that and the distributor are there any other complatible problems .
thanks alot rob
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 24 January 2010 - 10:39 PM
Yes - that should be fine. Take the chance to fit a better cam while you are in there!
#3 Cooperman
  • 23,366 posts
Posted 25 January 2010 - 05:16 PM
Use the original primary gear as the A+ transfer gears are different.
As 'bmcecosse' says, a better cam such as the MG Metro or Kent 266 would be a good thing to do whilst it's in pieces.
#4 valve bounce
valve bounce
  • 694 posts
Posted 25 January 2010 - 08:15 PM
thanks guys ive been planning this build for while but have had the cash (apprentice mechanic on little wages) so the spec:
kent 276 cam with duplex timing gear
12g295 head with 33 inlets 27exhaust been ported
striaght cut drop gear
28/36 webber
small bore lcb with rc40
flat top pistons in A+ block
a serise crank flywheel clutch set up
all rotating parts balanced (pressure plate and flywheel lightened)
proberly fogot somthing
advise and opinions apreciated (aslong as they dont read "fit 12g940 head")
robert
#5 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 25 January 2010 - 09:03 PM
dont bother with the webber just keep the su or upgrade to the hiff38 with the head you have i wouldn't go hiff44 but others do and works ok but i have found you lose a little bottom end power. you wont need straight cut drops for that spec but assume your going for the noise. 998cc straight cut drops are not cheap
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 January 2010 - 09:19 PM
I agree! Dump the ghastly Weber - and straight cut drop gears are a waste of money except for full blown race/rally engine. As many on here will know - I prefer the 940 head - but try the 295 since you have it! It will be fine.
#7 valve bounce
valve bounce
  • 694 posts
hiff38 you wont need straight cut drops for that spec but assume your going for the noise. 998cc straight cut drops are not cheap
already have a hif which works REALLY well but the webber was just a stand out from the crowd abit and the striaght cut drops i love the noise and if there going to cut down on transmision losses even better
thanks everyone robert
#8 bmcecosse
bmcecosse
  • 9,699 posts
Be sure to put a centre oil pick-up in the box!
#9 valve bounce
valve bounce
  • 694 posts
Posted 25 January 2010 - 09:23 PM
way ahead of you there did it last winter when i rebuild the engine and box
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 January 2010 - 09:28 PM
Excellent!
#11 valve bounce
valve bounce
  • 694 posts
Posted 25 January 2010 - 09:29 PM
thought id add 3.4 diff and 10 inch wheels will be used,
does anybody have any other sugestions on the spec
#12 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 January 2010 - 09:31 PM
!0" wheels are what the car was designed with! Go for it. Final drive ratio is your choice - but for climbing up Shap.........
#13 In-a-mini
In-a-mini
  • 831 posts
Posted 25 January 2010 - 09:34 PM
straight cuts dont really save any power losses unless they are the roller bearing ones which help a bit. they are just stronger and dont side load the cases. i know what ya mean about the noise tiss good.
