Pcv Valve Disassembly
Posted 25 January 2010 - 01:30 PM
Any help appreciated,
Rich
Posted 25 January 2010 - 08:38 PM
Posted 25 January 2010 - 09:11 PM
Posted 25 January 2010 - 09:12 PM
Posted 26 January 2010 - 09:37 AM
That's because it's a non service item...
But you can by replacement diaphragms from minispares, and service kits from somerford. Surely this makes it a serviceable item...
Thanks for replies,
Rich
Posted 26 January 2010 - 10:07 AM
I make the assumption that you mean the one on the bulkhead ( the older one on the rear subframe is servicable but as bmc* says, this was eventually done away with
Edited by Guess-Works.com, 26 January 2010 - 10:13 AM.
Posted 26 January 2010 - 10:39 AM
I read PCV valve as being the one on the inlet manifold on early cars for crankcase ventilation. Where does bulkhead and rear subframe mounting come into it?
If my understanding is correct then you will probably have to lever the top out with a small screwdriver down the side. A strong magnet may help too as I guess the cover is steel whereas the body is cast alloy.
Posted 26 January 2010 - 11:33 AM
Yes i meant PCV valve as positive crankcase ventilation on the inlet manifold. I tried levering the top out, but didnt want to try too hard and break something. A magnetic is a genius idea, i shall try that aswell.
Cheers,
Rich
Posted 26 January 2010 - 11:40 AM
Posted 26 January 2010 - 01:35 PM
my apologies.... was obviously not awake....
Not a problem, it happens. Thanks for the reply anyway
Posted 26 January 2010 - 01:49 PM
Posted 26 January 2010 - 01:51 PM
Posted 26 January 2010 - 02:00 PM
It should just be held together by the spring clip that goes over the top. If it won't pull apart it's probably a perished diapragm holding it together. How about a blast from an airline with the inlet blocked off?
I have removed that, i think it is just a bit corroded. I just didnt want to start over stressing it, having not taken one apart before.
For the price of the diaphragm I would be sacrificing it and then be happy in the knowledge I had overhauled the valve with a new one.
That was the plan, get inside and have a look what the condition is like, its only £5 for a new diaphragm! Am i correct in thinking that when i fit this valve, if it fails then the crankcase pressure will become excessive and cause more oil leaks?
Posted 26 January 2010 - 02:47 PM
Posted 26 January 2010 - 03:15 PM
Thanks for all replies,
Rich
