Complete Electrical Failure Whilst Driving
Posted 25 January 2010 - 10:58 PM
No ignition lights or any other power.
Driving along last night and then literally within a split second the car died, no electrics atall
When we tried jump starting the car, underneath the bonnet the heater cable was sparking away on the manifold and still no electric power
This lead me to believe it was a split wire shorting out somewhere, i checked every single wire this morning and nothing
little help guys??
Posted 26 January 2010 - 12:13 AM
Edited by mini_mad_daps, 26 January 2010 - 12:14 AM.
Posted 26 January 2010 - 12:24 AM
Posted 26 January 2010 - 12:45 AM
i thought it was a bit weird cus i had only recently done the wiring and i new it was in good condition
is there a quick fix to the earth strap? cus my poor mini is abandoned the other side of town and id really like to bring him home
Posted 26 January 2010 - 01:13 AM
Posted 26 January 2010 - 11:43 AM
Posted 26 January 2010 - 11:52 AM
Posted 26 January 2010 - 12:46 PM
Posted 26 January 2010 - 02:17 PM
Hope this helps, Johneh.
Posted 02 February 2010 - 06:20 PM
i replaced both the battery and engine earths with new ones, cleaning the areas first
and stilll nothingggg
replaced the battery and the new one blew up
still sounds like an earth issue but both are fine???
any ideas?
Posted 02 February 2010 - 06:24 PM
rightio little update
any ideas?
I would suggest a major short - check the positive cable all the way from the battery to the starter solenoid for anywhere that is bare cable, and touching the body.
Posted 02 February 2010 - 06:25 PM
but i could check again, no harm in trying
Posted 02 February 2010 - 06:43 PM
hhmm i have checked, had it up on the ramp and everything was fine
~ just with you saying the new battery blew up, this must have been drawing a lot of current, thus i suspecte the main battery underneath the car.
Have you got a multimeter or "power probe" with continuity setting? if so, disconnect both batter leads, and the main feed at the front to the starter solenoid, then put one end of your meter to the cars body / engine block, and the other end to the ring connection of the positive lead. If there is continuity here - there shouldn't be, and the positive cable shoudl be re-checked. Doing it this way means you are not using the large 12V battery, only the meters own current = safe.
Edited by L400RAS, 02 February 2010 - 06:44 PM.
Posted 02 February 2010 - 06:48 PM
Posted 02 February 2010 - 08:51 PM
