Gear Knob Thread
9 replies to this topic
#1 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
  • Local Club: NO CLUB HERE.... YET
Posted 26 January 2010 - 11:01 PM
I bought a new gear knob to replace this one:
but once removing it... I found out that the thread had been cut off and all that was underneath the green one was the post with no thread...
How can I go about fitting the new gear knob? its a "CLASSIC MINI 500 GEAR KNOB"
Jason
#2 hazpalmer14
hazpalmer14
  • 684 posts
  • Local Club: cumbria mini cruisers
Posted 26 January 2010 - 11:03 PM
make a new thread with a tap and die set
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 January 2010 - 11:08 PM
The thread is considerably slimmer than the rest of the shaft, you would need to get the end waisted down on a lathe before you could thread it again. It's also far too short already, someone's cut loads off. Maybe as much as 4". That's fine if you like it like that I suppose but it's kind of the opposite of a quick shift! Personally I'd say your best bet is a new gearstick.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 January 2010 - 08:17 AM
easier just to put a replacement gearstick in, will take all of two minutes....
I'm sure you'll be able to pick on up at bingley in the autojumble
(note to self, find all gearsticks and pack :thumbsup: )
by the way.... the thread is 5/16 UNC for a normal mini gear knob
Edited by Guess-Works.com, 27 January 2010 - 08:18 AM.
#5 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
Posted 27 January 2010 - 11:22 AM
That quite a lot off... I don't know whether id like a longer one now... got used to this one...
Does anyone have a picture of a full length one in? so I can see what it looks like?
#6 R1minimagic
R1minimagic
  • 4,660 posts
Posted 27 January 2010 - 11:30 AM
Here
Other option is to get a new shaft, cut a piece out, turn ends down to a taper and weld it back together again
Edited by R1minimagic, 27 January 2010 - 11:32 AM.
#7 Ethel
  • 25,990 posts
Posted 27 January 2010 - 12:18 PM
or drill the end to take a stud.
#8 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 27 January 2010 - 12:58 PM
Or you could consider a quickshift (shortshift) while you are at it and replace the lot? And before the thread decends into an arguement about how good or bad they are lets just leave it at this. We are presenting the OP with all his options!
Edited by Stewart_GT, 27 January 2010 - 12:58 PM.
#9 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 27 January 2010 - 10:19 PM
I have a spare gearstick in the shed.
PM me if you need one
#10 1995 MK2 IOM
1995 MK2 IOM
  • 810 posts
Posted 29 January 2010 - 06:34 PM
thanks all.
Might put a new one on.
Will have a look tomorrow any see what I feel when I drive it... (the old one still stays on...)
I most certainly want to get rid of that frog thing... wonder if anyone would buy it if I stuck it on Fleabay! lol
thanks
Jason
