I think i will get some of the grooved disks from minispares, they always seem to sell stuff that works, and does exactly what it says, unless anyone can tell me the drilled ones are definatly better.
Planning on refurbing the calipers now, allong with braided hoses all round, new rear shoes and cylenders.
If its not good enough i will get some of the C-M pads, (
http://www.minispare...ty=pb&pid=32846 guessing these are the right ones then? ) but will plan on getting a set when the green stuffs are dead anyway.
Ive been reading an article in an old mini mag which says that if you are running the 7.5s up front you need a different pressure valve or something. can anyone explain this to me or show me what parts i need?
It would apear that my front brake lines run through a pressure valve allong with the rear pipes, is this limiting the pressure on the front?
Chris
