Adjusting Front Brakes
Posted 28 January 2010 - 06:33 AM
how difficult could this be.
Thx
Flye
Posted 28 January 2010 - 07:01 AM
Posted 28 January 2010 - 11:32 AM
Posted 28 January 2010 - 02:22 PM
Posted 28 January 2010 - 02:28 PM
Its only the adjusting of them that temps me into fitting 7.5" disks, other than that the brakings fine when adjusted right.
Have to use an open ended spanner on the top adjuster cant get a proper square brake adjuster spanner on it.
Edited by lrostoke, 28 January 2010 - 02:29 PM.
Posted 28 January 2010 - 03:13 PM
I've found you do have to adjust the front brakes so the shoes do rub, obviously not so much as you can't turn the wheel but so you can feel a bit of friction.
Yes I have to agree with that. There should be a little drag, the wheel shouldn't simply spin freely. The only tricky part is getting both shoes on each brake adjusted to the same level.
Posted 28 January 2010 - 03:22 PM
Posted 28 January 2010 - 08:12 PM
this is what i use for adjusting the top unacessible adjuster
http://www.minispare.....20SPANNER A...
and this for all the others. but i think you can use the first one only
Posted 29 January 2010 - 08:24 PM
