What Tools Are Needed To Remove Engine?
Posted 29 January 2010 - 12:17 PM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
MMayfair
1984:
Hello all,
Just a quick question. I am removing my engine tomorrow. Are there any non standard tools I will need?
Just asking so I can get them in advance.
Cheers,
Richard
Posted 29 January 2010 - 12:20 PM
Edited by PhilipGCaldwell, 29 January 2010 - 12:21 PM.
Posted 29 January 2010 - 12:24 PM
Posted 29 January 2010 - 01:15 PM
Any more advice all greatfully recieved.
Posted 29 January 2010 - 01:39 PM
Are taking the engine out through the top, ie lifting it, or planning to just drop the subby and lift the body ver the engine?Thaks for your replies. I think I'll pick up a scisser type ball break (I have the fork type) as I'd rather not damage the ball joint.
Posted 29 January 2010 - 01:45 PM
Posted 29 January 2010 - 01:48 PM
Posted 29 January 2010 - 01:50 PM
Fork lift thats just cheatingIm lucky, I've got a forklift in my unit. I took it out through the top and it IS the best way. Just make sure you've undone EVERYTHING before you lift. Oh, and get a container for the oil when you seperate the pot joints!!! very messy otherwise.
Posted 29 January 2010 - 01:51 PM
Fork type is fine though sometimes splits the rubber - it won't damage the ball joint.
The only other thing I can think you'll need is a 5mm drift to knock out the roll pin in the gearchange.
Posted 29 January 2010 - 01:57 PM
Not sure where I would pick up a drift, would halfords sell them. Can't see them ont heir website.
Posted 29 January 2010 - 02:01 PM
Always one for the easy option me! lolFork lift thats just cheatingIm lucky, I've got a forklift in my unit. I took it out through the top and it IS the best way. Just make sure you've undone EVERYTHING before you lift. Oh, and get a container for the oil when you seperate the pot joints!!! very messy otherwise.
Posted 29 January 2010 - 03:47 PM
Posted 29 January 2010 - 03:54 PM
If just taking the engine out (easiest way if only engine problem) then you will need a flywheel puller. Saves all that faffing about with ball joints, drive shafts and gearbox pins - just leave the box in the car!
Im sorry but thats the worst way to take an engine out.
Pull it out complete.
Posted 29 January 2010 - 05:34 PM
